problem with HW acceleration (Radeon HD 5450)
c.link86
hello I'm trying to hackintosh a dell Optiplex 3020 (most specs in profile) nearly everything works except Graphics an older Radeon (HD5450) so again im stuck on HS Till i upgrade to a Metal 2 complient card but i'm still having issues with hw accel I'll add the run me tomorrow cause it's late now VGA works oddly w/o HW accel but the main problem lies in the HDMI It'll boot into clover but is a black screen after that (windows seems to have the same issue til i "activate" hdmi in catalyst by first entering windows with vga) if you need more info it'll have to wait til tomorrow
Link to comment
Share on other sites
-Haswell
in ur case u need activate intelhd for hardware accel and correct properties injected by weg kext
Link to comment
what are the correct properties? for weg?
first, just enable and check if weg inject correct properties
Link to comment
no dice kept blackscreening/rebooting but doing shikigva=128 boots w/o accel i checked the kp logs and found this line standing out
panic(cpu 0 caller 0xffffff7f976afdcf): WhateverGreen: shiki @ Hardware DRM decoder cannot be used with custom board or whitelist
Link to comment
Link to comment
i checked ur ioreg and ur principal gpu is not activate, first u need solve it, try it radeondelnit option in graphics tab
Link to comment
tried that just now didn't work (currently using vga) edit: can now boot into hdmi still no HWA something with SIP prevented boot i changed 0x28 to i think 0x2e7 (allow unapproved kext) also changed shikigva=60 to 80 i have deinit on when macos loaded it said "a kext prevented macos to boot all 3rd party kext are now disabled" so we are getting somewhere atleast
Link to comment
got it but didn't use weg options.... it maybe not supported here but he was the solution
I used
ATI FakeID = 0x68E01002
FBName = Cedar
InjectATI = True
VideoPorts = 3
at first it caused color problems flashing colors but using a paid app temporarly (SwitchResX trial) I switched the color mode from billions to millions which fixed the issue plus i got full hwa + underscan so i got the desktop to fit unlike my nvidia GT730 thanks for the help
Link to comment
