Hi everyone, I hope you can help me :)
I have some troubles with my patch dsdt founded on this forum.
- I have no sound with the proper DSDT
- Hibernate leaves the fans running and it is impossible to wake up the pc.
- Sleep rebooting the pc.
- The extinction works but I can see the console instead of the spinning wheel and reboot, I have a freeze at the start of Chimera.
- My printer HP, attempts to print a test page alone sometimes.
My stuff:
GA-G41MT D3V
2.83 GHz Quad-Core Intel Xeon X3360
8 GB 1333 MHz DDR3
ATI Radeon HD 5770 1024 MB
BCM4318 802.11g Wireless LAN
My BIOS setting "Enabled"
HDD S.M.A.R.T / C1E / C2+C2E / TM2 / EIST Function / Virtualization / ACPI S3(STR) / HPET 64bit
My kexts (from multishit 4.2.1) in S/L/E:
ALC8xxHDA.kext
HDAEnabler889.kext
IOAHCIBlockStorageInjector.kext
FakeSMC.kext
ACPIMonitor.kext
IntelCPUMonitor.kext
SuperIOFamily.kext
My Bootloader :
Chimera 1.7
Use Kernel Cache
Ethernet Built In
Generate P and C States
Graphic Enabler
My Files for debbuging :
org.chameleon.Boot.plist http://cl.ly/2N303e0u163Y0R2C1r2H
smbios.plist http://cl.ly/1f300i0R2A3T3W352H3C
dsdt.aml http://cl.ly/2N303e0u163Y0R2C1r2H
bdmesg.txt http://cl.ly/1638080m3Y443P3K3x3j
Thanks for your help :)
About the reboot bug on sleep mode.
That is the Realtek driver who made the Kernel Panic. I disabled the ethernet port into the bios and the sleep mode work now
The auto time sleep function work fine, but it's not ok by the Apple menu Suspend.
Don't use both HDAEnabler889.kext and HDEF patch in DSDT at same time, use one or other.
ALC8xxHDA.kext only works with AppleHDA "rollback" (from 10.6.2).
Read this http://Olarila.com/forum/viewtopic.php?f=17&t=212
or use VoodooHDA http://Olarila.com/forum/viewtopic.php?f=18&t=454
Ok, i have the same board, GA-G41MT-D3V, i did the modification found by schatten, here is the link again so you can download the kext for the audio: http://www.tonycrapx86.com/audio/26439-alc889-applehda-kext-10-7-x-lion.html
I removed the voodoohda i was using, and installed the modified applehda.kext they are providing.
I can tell you the audio sound great, i can put the volume at half of what it was before, for the same level, but without the white noise.
Sleep is not working for me thought.
