Hi,
I am trying to install Catalina with the Olarila-Catalina image.
The installation process works until the first reboot.
After I boot into clover on that reboot again, I can only see the Catalina data partition, there is no entry something like "Install macOS Catalina".
The result is, I cannot complete the Catalina installation.
I have tried to choose the Catalina data partition, the installer comes up though, it always starts at 13 minutes left. I chose the data parition at least 5 times with no success.
Does anybody know, why I am only able to see the data partition and not the install partition?
My harddrive is a 120GB SSD drive and I am connected using a Display-Port to HDMI cable.
Thanks!
Matt
ASUS Prime Z390-P, i7-9700K, Sapphire Radeon RX580 Nitro+
[ref]Cayman12[/ref], after first reboot u use boot key again? asus is f8
[ref]Cayman12[/ref], :shock:
Hi,
just to let you guys know, I detached all my harddrives except the one SSD i wanted to install Catalina on.
With this configuration I had no problem. I went through the installation process without any errors.
While reboot and booting into clover I only saw the Install macOS partition - the data partition didnt show up.
Cheers,
Matt
Sorry, no more ideas.
I recently switched to new hardware. No problems with the installation including the update to 10.15.2
