Hello everyone, first of all I thank you especially because my hackintosh works thanks to you and your guides. :D
The problem occurs during shutdown and restart. The screen goes black, but in both cases the PC stays on. In order to switch off or restart I have to force it manually.
This also does not allow me to make system updates.
I made several attempts, but I can't find a solution.
My hackintosh consists of:
- Gigabyte GA78LMT rev 6.0.
- AMD FX 6350 - 16GB RAM
-Gigabyte GeForce GTX 1070 8GB.
Thanks for your attention, I hope someone helps me.
You are great!! :D:D:D
config.plist.zip
my kext.zip
[ref]Natu4al[/ref], genericxhci is ur problem
Good evening, thanks for the help. :laugh:
The problem was just that kext.
Currently, however, I have another problem, I can't make the security update "SecUpd2019-006HighSierra". It freezes in the screen as the attached photo.
The WebDriver insall, however, it works, but it does not leave an icon in System Preferences.
Thanks again!! :)
freeze.jpg.zip
