Hackintosh Guide - Mojave / Catalina / Big Sur / Monterey on AMD RYZEN / THREADRIPPER / ATHLON2xxGE with OpenCore Bootloader/ Full DSDT Patches
7 hours ago, Wifi75 said:
Thunderbolt doesn't interest me, so I'd take the Gigabyte or Asus Z590 chip, any model, one I like ..
any z590 gigabyte
Hi, Thank you for the great  post. I tried to install Big Sur but I was not successful. I have attached a photo of the error.
My system spec is :
CPU: AMD Ryzen 5 4600H
Motherboard: ASUS FA706IU
Computer Brand Name:                                                            ASUS ASUS TUF Gaming A17 FA706IU_FA706IU
Please help me to install it. Thanks
20210702_174923.zip
10 hours ago, Mahdi Ghorbanpour said:
Hi
https://tinyurl.com/y6g7mn3b
reset nvram one time
check bios'uefi config
Thanks for the quick reply, I deleted the EFI folder in the usb EFI partition and copied the files from the zip. I also tried the Reset-NVRam twice. still I get the same error screen. Regarding the bios config, what should I do? I checked the bios has no CSM configuration. It has Secure-Boot which is disabled.
Hi @MaLd0n I got a succes on asus rog strix B450-F, ryzen 3600 with Saphire RX580 gpu. I just and only use your efi folder to install and post-installation. I got full video hw acceleration and audio, everythings is working fine. Do I need to patch something else...?
Is there other anyway to control case fans speeds and  gpu fan speed(like radeon software)?  I can manage fan speeds with the  AMd power gadget but there is one connector, the aio pump where is a 120mm fan connected that do not respond to Amd power gadget fan control and always stays at full speed.
Thanks so much.
Edit: How can I make  hw monitor works to show all the devices and sensors. I used  to have it working but  that was on an intel platform long time ago.
Edited by Osk
miss some info
here we used a full solution with full dsdt patched, but this folder work good
Hi MaLd0n
My specs is
+Ryzen 5 3500
+Sapphire Nitro RX 580
+MSI B450M Mortar Max
I already did all the steps needed for my fresh installation to Monterey Beta 6 (I've used Catalina before). BIOS settings is fine
I made all needed modifications to config.plist as instructions (my 3500 has 6 cores) and replace edited EFI folder to your vanilla image. However, I can't pass the boot stage. The console runs completely fine but stuck at the gray screen, nothing happens.
I have no idea what I need to do to fix this. Any suggestions for me?
I really appreciate your help!
seems like a video problem
Thanks man !
I forgot that I'm having two monitors are connected at the same time. Unplugged one and everything works fine. What a funny mistake. ?
Cheers!
disable csm on bios/uefi
use last bios/uefi version
buenas tardes.tengo un amd ryzen 3900x y una 2080ti.he intentado instalar ios un millon d veces pero nada o se me queda la pantalla en negro o no llega a comentar a instalar, estoy un poco desesperado,despues de usar 8 años mi imac como primer pc estoy ahora con esto que ni por asomo me da lo que necesito, el balena me da error al montar casi el 90% de las imagines por lo que estoy usando rufus.y nose si en los videotutoriales se saltan algo de la bios pero cambio las mismas opciones y no hay forma
3 hours ago, Jordan JCR said:
2080ti
this card don't work. need change
Hi again @MaLd0n my rig is working great but one little problem. I can't erase and mount disks, I always got errors like 5 input/output etc and after boot Os says that there is a unrecoignazible disk. That happened with a new kingston ssd A400 (intended to be the system disk) and two 2.5 hdd, I samsung nvme 970 evo. I try it from recovery and from the installation usb no luck. Do you think that there is a problem with some patch or sata driver? Do I need an extra patch? or there is a mobo problem but with previos version of macosx and same hardware that didn't happened
This is one of the errors I got
Erasing “Samsung SSD 970 EVO Plus 500GB Media” (disk0) and creating “Untitled”
Unmounting disk
Creating the partition map
Waiting for partitions to activate
Formatting disk0s2 as Mac OS Extended (Journaled) with name Untitled
Initialized /dev/rdisk0s2 as a 465 GB case-insensitive HFS Plus volume with a 40960k journal
Mounting disk
Creating a new empty APFS Container
Unmounting Volumes
The volume “Untitled” on disk0s2 couldn’t be unmounted because it is in use by process 0 (kernel)
Couldn’t unmount disk. : (-69888)
Operation failed…
Big sur last version
hardware: asus rog strix B450-F, ryzen 3600 with Saphire RX580 gpu
I'm using your EFI folder untouched
Edited by Osk
missing info
5 hours ago, MaLd0n said:
https://www.transfernow.net/dl/20211021HrmaPKWJ
The problem is mainly with macosx formatted drives, disks with windows ntfs are mounted with no problem. macosx drives do not mount and any drive can´t be erased into any file system with disk utility neither from terminal.
the best is update ur folder to "new way" amd patches
check last olarila folder
The thing is that I had to use saved old olarila efi folder because the last one do not boot. I checked and the default cpu ID was correct, I have a ryzen 3600 and I think is the default in your folder. I tried different bios settings and was unable to boot the install usb neither the system from the ssd....?
But I'll try again, as I see now the last olarila fodler is from oct 13 and I think I installed the system a few days before that with the previus folder with no luck.
Thanks. I'll write back with the results
On 10/23/2021 at 1:51 PM, MaLd0n said:
Hello. using your new folder and with the correct core count for my cpu always got stuck on apfs_module_star:2485: .. at boot,  after some research fin out that I needed SSDT-EC-USBX.aml patch, put it in acpi folder and everything works perfect. For you to know in case that someone ask you about getting stuck in the same place at boot.
Your new folder do not correct my initial problem but I already fix it, sata hot plug have to be deactivated in Bios, otherwise mac drives will not mount and can't erase/format them in mac file systems.
I just do a clean install with big sur 11.6.1 in a new SSD and everything went perfect.
Thanks, you put me in the right direction of cheking kernel patches etc.
