Hackintosh Guide - Mojave / Catalina / Big Sur / Monterey on AMD RYZEN / THREADRIPPER / ATHLON2xxGE with OpenCore Bootloader/ Full DSDT Patches
4 hours ago, trinetlx said:
Thanks sir, I did it. Last question, can I change my hardware ( like CPU) without reinstalling hackintosh?  I want to upgrade to 3900X in the near future.
yes
On 6/12/2020 at 6:43 PM, MaLd0n said:
just paste efi folder into efi partition. and reboot from ssd
Thank you one more time for this help. Is there a way to get facetime and imessage working or any guides for me to follow for my Ryzen 1600X X370 system? I have tried a bunch of them but nothing works.
check google. have many ;)
Apple store works but for some reason those won't. I have done all what I can, is there a specific one you'd recommend for me?
Sorry if this isn't where I need to post this but I am curious to know if the bootloaders in "Folders for all chipsets" is updated accordingly? Thank you. @
soon
u just need compile and replace files for update bootloader
Hi guys. I am having this issue with installing Catalina 10.15.5. I am using Opencore 0.5.9 and below are my specs. It's very weird because the installation for Catalina 10.15.1 went without any problem for me. But for Catalina 10.15.5, I am getting errors during booting.
- 3600x Ryzen, x570 Gigabyte Aorus Master, Rx 5700 XT.
I will include EFI I used. Please let me know if there is something I need to fix. Thanks in advance.
config.zip
have some patches update
check here
https://github.com/AMD-OSX/AMD_Vanilla
On 7/12/2020 at 10:29 PM, Filipe tiolip said:
Estou tendo um problema baixei a imagem OLARIA CATALINA AMD da boot e para no final do carregamento da tela de logo da APPLE
12 hours ago, longcoming said:
I am trying to make sleep/wake work on my Ryzen machine.
in big sur sleep work
x86platform is load
x86platform is load
Thanks a lot Mald0n.
System sleeps but doesn't wake up.No signal on monitors.
Edited by longcoming
sleep in amd dont work for all
amd don't have native support
