Hackintosh Guide - Mojave / Catalina / Big Sur / Monterey on AMD RYZEN / THREADRIPPER / ATHLON2xxGE with OpenCore Bootloader/ Full DSDT Patches
successfuly managed to install. I had to enable "Above 4g memory" at bios.
Everything working properly,except my mouse. Seems to be very laggy and "jumping".  It could be a kext problem,perhaps...?
Edited by jvmachado95
On 4/29/2020 at 2:45 PM, MaLd0n said:
yes
sorry to bother you again sir.
The same thing happened to my intel laptop.
i manage to fix wifi lan audio touch pad hd4400 showing 15xx mb and smooth without the DSDT file you gave me for my i3 4005u hd4400 laptop Currently high sierra.
But when i transfer the DSDT patch to acpi > patched folder reboot my hd4400 shows 4mb only and it lags with ui glitch audio stops working and touch pad.
edit ur dsdt for usb or use one injector
use a correct video patch
Got it. Well,i'm kinda newbie,so... How can I edit dsdt properly? I'm kinda lost with opencore, although I managed to install Cat
On 4/30/2020 at 12:03 AM, jvmachado95 said:
greetings
currently facing this bug when attempting to boot from Catalina AMD 10.15.4 " In memory panic stackshot succeeded  ** bytes traced 120/250 ** and then the system freezes.
Is there any solution? I'm kinda lost...
Ryzen 5 1600 AF +Nvidia GT 710 . Working fine with olarila mojave.
Having similar issue with Crosshair VII x470. Tried OpenCore folder and gets stuck loading Lilu. Guess I'll stay with Clover and 10.15.1 :(
My installation, using the EFi folder with Opencore, is stopping with this message "efend authenticated restart support" do I need to complete any more steps?
try this folder guys
EFI.zip
7 hours ago, Gian and Charize Travels said:
@MaLd0n I installed Mojave opencore to my ryzen build and after installation i cave the DSDT patch to acpi > i created a patched folder paste the DSDT file reboot and check system report > PCI and it doesnt display anything.
OC/ACPI
I have a problem after hibernating, it reactivates well, but if I have a usb stick connected, it shows me that the usb drive did not eject correctly.
I use catalina 10.15.4, open core 0.5.8, ryzen 7 2700, msi b450 mortar max and rx570 4gb.
Do you think there is a solution?
Edited by Jonathan Cass
1 hour ago, Jonathan Cass said:
I have a problem after hibernating, it reactivates well, but if I have a usb stick connected, it shows me that the usb drive did not eject correctly. I use catalina 10.15.4, open core 0.5.8, ryzen 7 2700, msi b450 mortar max and rx570 4gb. Do you think there is a solution?
some real apple have it too
9 minutes ago, Jonathan Cass said:
I have to remove and put the USB stick to recognize it again, do you think there would be no solution?
55 minutes ago, Jonathan Cass said:
Here you have it,
Archive.zip
I have tried and continue with the same problem in the usb, I have made a new installation of catalina with just enough, in OC / ACPI I only have DSDT.aml and DSDT.aml that you put me.
Can you think of something to try?
Thank you very much for your help.
6 hours ago, Jonathan Cass said:
I have tried
extract new send_me
7 hours ago, Jonathan Cass said:
I put the new
create one usb injector with hackintool
the config looks good
Olá,
Como faço para aplicar os patchs de dsdt para usar com o OpenCore? (Ryzen)
Eu usei o Clover para pegar os arquivos, e agora como proceder?
Adicionei os arquivos aqui  caso alguém puder ajudar.
origin.zip
