Hackintosh Guide - Mojave / Catalina / Big Sur / Monterey on AMD RYZEN / THREADRIPPER / ATHLON2xxGE with OpenCore Bootloader/ Full DSDT Patches
[ref]cupecups[/ref], u can try, but need others patches
Hi MaLd0n,
Would you say there is a big difference between running AMD and Intel Hackintosh? More stable. less stable?
Do you recommend one over the other...?
Thx
[ref]tsader[/ref], amd don't have native support, apple use intel only, use intel
Can anyone solved this error?
post one photo
Hello all,
I have been trying to setup up this AMD build for a while now. I have always used Apple computers yet am somewhat familiar with hackintosh back in the netbook days dell mini 9's etc, as well as hacking the MacPro 1,1 to continue on with the new MacOS releases. I for the life of me can not get open core to boot. When I select the open core UEFI in my bios boot menu it just flash and goes back to the selection screen. I have got the base system up and running with clover it appears, but need to convert to open core and update so my 5700xt works the way it is suppose to, I have a three monitor Eyefinity setup and it will only display one 1 screen currently.
AsRock B450 Steel Legends
Ryzen 5 3600
32gb ram
I have copied your EFI file set and it appears that it won't load the efi instantly reverting back to the bios boot loader. Any ideas as to what is wrong with OC?
Hi @MaLd0n,
I have a hackffi with:
Mainboard: Asrock B450M pro4-f
CPU: AMD Ryzen 3500X
VGA: XFX HD 7730.
I use clover bootloader for Mojave 10.14.6 and it recogenize VGA with fakeID and injectATI (HD7730: 0x68371002 -> HD7750: 0x683F1002) full supported for everything. When i update from 10.14.6 to 10.15.2, i used OC and fakeid and injectATI with tutorial:
https://khronokernel-2.gitbook.io/opencore-vanilla-desktop-guide/extras/gpu-patches
VGA not recogenize and supported.
I attached two config file of OC and Clover .I hope You can help me to resolve it. Thank you very much.
PS: i'm vietnamese so my english very bad. hope you understand things i wrote. :laugh::laugh::laugh:
OC catalina 15.2.zip
Clover Mojave 10.14.6.zip
VGA: XFX HD 7730
post one full dump
--Run_Me
RunMe.app
Hi, MaLd0n!
Check if work
This is wonderful. It work perfected. Thank you very much. You are nice men.
Enjoy!
Does Olarila images work for Intel+AMD Processors or must I use specified Olarila images for AMD processors?
I am an AMD processor user.
u can use image and specific efi folder
Same here, when trying to run RunME I get Increased delay x2 for IOREG dump. This will take a while...(33 sec)
--Run_Me
RunMe.app
Hi i have used Olarila image for my amd ryzen 3700x with gigabyte 5700xt but after select install osx from first boot i have black screen . What can i do?
