Hackintosh Guide - Mojave / Catalina / Big Sur / Monterey on AMD RYZEN / THREADRIPPER / ATHLON2xxGE with OpenCore Bootloader/ Full DSDT Patches
remove all acpi files
Archive.zip
  • Thanks 1
Enjoy!
39 minutes ago, Sayori UwU said:
I cant copy efi folder to the flash drive since it's asking to format after flashing the image any help?
https://www.olarila.com/topic/12857-how-to-mount-efi-partition-on-macos-or-windows/
I don't know if this is the most appropriate place to talk about it, but as of the 12.3 update, AppleMCEReporterDisabler.kext has become mandatory, at least for those using an AMD processor, in my case. So I suggest adding this kext in the next update of the EFI folders to Desktop.Bulldozer.Jaguar.Ryzen.Threadripper.
ok
i'll check it
Hi @MaLd0n  I'm looking in other forums with no luck, did you know something about the fix for SmallTreeIntel82576 kext or way around that Intel nic on Monterrey?
Self answering. I managed to get a stable and working conecction so far by using this AppleIGB kext for the intel i211 nic on  Asus b450-F https://github.com/donatengit/AppleIGB/releases
I have to manually set the speed to 100mb half duplex, other speeds only works for a few minutes.
