[Guide] Native USB Fix for Notebooks - No Injector/Kext Required
--Donations via PayPal--
https://tinyurl.com/r2bvzm7
This procedure work in many desktops too, chipsets series 5, 6, 7, 8, 9, X79 and x99
Thanks to Piker-Alpha to open our eyes about it
Connector types in the ACPI specification(pages 524 and 525)
https://uefi.org/sites/default/files/resources/ACPI_6.0.pdf
-Open DSDT, use Maciasl
Download https://www.olarila.com/files/Utils/MaciASL.app.zip
GitHub https://github.com/acidanthera/MaciASL
in some Notebooks have a different way, check here
-Search for XHC/RHUB and you see all USB ports
Let's start work
some observations
-In some cases some ports have a Method _STA = Zero, change to 0x0F to enable
-Chipsets with EHCI devices(Skylake-), use Connectors type Zero(USB 2) for EHCI devices and 0x03(USB 3) for XHCI device
-Chipsets with only XHCI device(Skylake+), use Connectors type 0x03(USB 3)
-Internal Devices like Bluetooth and Cam, set to Internal 0xFF
-USB-C port set to 0x09
1- Enable / Disable Unused Ports
Check Name _UPC inside device, you need configure all ports, one by one
Enable = 0xFF
Disable = Zero
Device (HSP1)
Name (_ADR, One) // _ADR: Address
Name (_UPC, Package () // _UPC: USB Port Capabilities
0xFF, Port is Enabled
0x03,
Zero,
Zero
Device (HSP1)
Zero, Port is Disabled
0x03,
Zero,
Zero
2- Connectors Type
Device (HSP1)
0xFF,
0x03, Set USB 3
Zero,
Zero
0xFF - internal
Zero - USB 2
0x03 - USB 3
0x09 - USB-C
Connector types in the ACPI specification, check page 524
Example
Device (XHC1)
           Name (_ADR, 0x00140000)  // _ADR: Address
           OperationRegion (XPRT, PCI_Config, Zero, 0x0100)
           Field (XPRT, AnyAcc, NoLock, Preserve)
               DVID,   16,
               Offset (0x10),
               XADL,   32,
               XADH,   32,
               Offset (0xA2),
                   ,   2,
               D3HE,   1
           Method (_MOD, 0, Serialized)  // _MOD: Mode
               Local0 = (XADH << 0x20)
               Local0 |= XADL /* \_SB_.PCI0.XHC1.XADL */
               Local0 &= 0xFFFFFFFFFFFFFFF0
               OperationRegion (SPIO, SystemMemory, Local0, 0x9000)
               Field (SPIO, AnyAcc, Lock, Preserve)
                   Offset (0x560),
                   SP3C,   1,
                       ,   4,
                   LNK3,   4,
                   PWR3,   1,
                   Offset (0x570),
                   SP4C,   1,
                       ,   4,
                   LNK4,   4,
                   PWR4,   1,
                   Offset (0x80B8),
                   SPU1,   1,
                   SPU2,   1,
                   SPU3,   1,
                   SPU4,   1
               P80B = 0x71
               SPU3 = One
               SPU4 = One
               Sleep (0x03E8)
               If (((LNK3 == 0x06) || (LNK3 == 0x07)))
                   If ((SP3C != One))
                       SPU3 = Zero
               If (((LNK4 == 0x06) || (LNK4 == 0x07)))
                   If ((SP4C != One))
                       SPU4 = Zero
               Sleep (0x03E8)
                   If ((SP3C != One))
                       SPU3 = Zero
                   If ((SP4C != One))
                       SPU4 = Zero
           Method (_S3D, 0, NotSerialized)  // _S3D: S3 Device State
               Return (0x03)
           Method (_S4D, 0, NotSerialized)  // _S4D: S4 Device State
               Return (0x03)
           Method (_S3W, 0, NotSerialized)  // _S3W: S3 Device Wake State
               Return (0x03)
           Method (_S4W, 0, NotSerialized)  // _S4W: S4 Device Wake State
               Return (0x03)
           Method (_S0W, 0, NotSerialized)  // _S0W: S0 Device Wake State
               Return (0x03)
           Method (_DSW, 3, NotSerialized)  // _DSW: Device Sleep Wake
           Method (_INI, 0, NotSerialized)  // _INI: Initialize
               If (CondRefOf (\_SB.PCI0.XHC1.RHUB.INIR))
                   ^RHUB.INIR ()
               Return (Zero)
           Method (USRA, 0, Serialized)
               If ((PCHS == PCHH))
                   Return (0x0F)
               Else
                   Return (0x0B)
           Method (SSPA, 0, Serialized)
               If ((PCHS == PCHH))
                   Return (0x11)
               Else
                   Return (0x0D)
           Method (_PS0, 0, Serialized)  // _PS0: Power State 0
               If ((DVID == 0xFFFF)){}
               If (CondRefOf (\_SB.PCI0.XHC1.PS0X))
                   PS0X ()
               Return (Zero)
           Method (_PS3, 0, Serialized)  // _PS3: Power State 3
               If (CondRefOf (\_SB.PCI0.XHC1.PS3X))
                   PS3X ()
               Return (Zero)
           Method (CUID, 1, Serialized)
               If ((Arg0 == ToUUID ("7c9512a9-1705-4cb4-af7d-506a2423ab71")))
                   Return (One)
               Return (Zero)
           Device (RHUB)
               Name (_ADR, Zero)  // _ADR: Address
                   If (CondRefOf (\_SB.PCI0.XHC1.RHUB.PS0X))
                       CSD0 (0x16)
                       PS0X ()
                   Return (Zero)
               Method (_PS2, 0, Serialized)  // _PS2: Power State 2
                   If (CondRefOf (\_SB.PCI0.XHC1.RHUB.PS2X))
                       PS2X ()
                       CSD3 (0x16)
                   Return (Zero)
                   If (CondRefOf (\_SB.PCI0.XHC1.RHUB.PS3X))
                       PS3X ()
                       CSD3 (0x16)
                   Return (Zero)
               Device (HSP1)
                   Name (_UPC, Package (0x04)  // _UPC: USB Port Capabilities
                       0xFF,
                       0x03,
                       Zero,
                       Zero
                   Name (_PLD, Package (0x01)  // _PLD: Physical Location of Device
                       ToPLD (
                           PLD_Revision           = 0x2,
                           PLD_IgnoreColor        = 0x1,
                           PLD_Red                = 0x0,
                           PLD_Green              = 0x0,
                           PLD_Blue               = 0x0,
                           PLD_Width              = 0x0,
                           PLD_Height             = 0x0,
                           PLD_UserVisible        = 0x1,
                           PLD_Dock               = 0x0,
                           PLD_Lid                = 0x0,
                           PLD_Panel              = "UNKNOWN",
                           PLD_VerticalPosition   = "UPPER",
                           PLD_HorizontalPosition = "LEFT",
                           PLD_Shape              = "UNKNOWN",
                           PLD_GroupOrientation   = 0x0,
                           PLD_GroupToken         = 0x0,
                           PLD_GroupPosition      = 0x1,
                           PLD_Bay                = 0x0,
                           PLD_Ejectable          = 0x0,
                           PLD_EjectRequired      = 0x0,
                           PLD_CabinetNumber      = 0x0,
                           PLD_CardCageNumber     = 0x0,
                           PLD_Reference          = 0x0,
                           PLD_Rotation           = 0x0,
                           PLD_Order              = 0x0,
                           PLD_VerticalOffset     = 0x0,
                           PLD_HorizontalOffset   = 0x0)
               Device (HSP2)
                   Name (_ADR, 0x02)  // _ADR: Address
                       Zero,
                       Zero,
                       Zero,
                       Zero
               Device (HSP3)
                   Name (_ADR, 0x03)  // _ADR: Address
                       0xFF,
                       0x03,
                       Zero,
                       Zero
                       ToPLD (
                           PLD_Revision           = 0x2,
                           PLD_Red                = 0x0,
                           PLD_Green              = 0x0,
                           PLD_Blue               = 0x0,
                           PLD_Width              = 0x0,
                           PLD_Height             = 0x0,
                           PLD_Dock               = 0x0,
                           PLD_Lid                = 0x0,
                           PLD_GroupPosition      = 0x3,
                           PLD_Bay                = 0x0,
                           PLD_Rotation           = 0x0,
                           PLD_Order              = 0x0,
               Device (HSP4)
                   Name (_ADR, 0x04)  // _ADR: Address
                       0xFF,
                       0x03,
                       Zero,
                       Zero
                       ToPLD (
                           PLD_Revision           = 0x2,
                           PLD_Red                = 0x0,
                           PLD_Green              = 0x0,
                           PLD_Blue               = 0x0,
                           PLD_Width              = 0x0,
                           PLD_Height             = 0x0,
                           PLD_Dock               = 0x0,
                           PLD_Lid                = 0x0,
                           PLD_GroupPosition      = 0x4,
                           PLD_Bay                = 0x0,
                           PLD_Rotation           = 0x0,
                           PLD_Order              = 0x0,
               Device (HSP5)
                   Name (_ADR, 0x05)  // _ADR: Address
                       Zero,
                       0xFF,
                       Zero,
                       Zero
                       ToPLD (
                           PLD_Revision           = 0x2,
                           PLD_Red                = 0x0,
                           PLD_Green              = 0x0,
                           PLD_Blue               = 0x0,
                           PLD_Width              = 0x0,
                           PLD_Height             = 0x0,
                           PLD_UserVisible        = 0x0,
                           PLD_Dock               = 0x0,
                           PLD_Lid                = 0x0,
                           PLD_Shape              = "VERTICALRECTANGLE",
                           PLD_GroupPosition      = 0x5,
                           PLD_Bay                = 0x0,
                           PLD_Rotation           = 0x0,
                           PLD_Order              = 0x0,
               Device (HSP6)
                   Name (_ADR, 0x06)  // _ADR: Address
                       Zero,
                       0xFF,
                       Zero,
                       Zero
                       ToPLD (
                           PLD_Revision           = 0x2,
                           PLD_Red                = 0x0,
                           PLD_Green              = 0x0,
                           PLD_Blue               = 0x0,
                           PLD_Width              = 0x0,
                           PLD_Height             = 0x0,
                           PLD_Dock               = 0x0,
                           PLD_Lid                = 0x0,
                           PLD_GroupPosition      = 0x6,
                           PLD_Bay                = 0x0,
                           PLD_Rotation           = 0x0,
                           PLD_Order              = 0x0,
               Device (HSP7)
                   Name (_ADR, 0x07)  // _ADR: Address
                       0xFF,
                       0xFF,
                       Zero,
                       Zero
                       ToPLD (
                           PLD_Revision           = 0x2,
                           PLD_Red                = 0x0,
                           PLD_Green              = 0x0,
                           PLD_Blue               = 0x0,
                           PLD_Width              = 0x0,
                           PLD_Height             = 0x0,
                           PLD_Dock               = 0x0,
                           PLD_Lid                = 0x1,
                           PLD_Panel              = "FRONT",
                           PLD_HorizontalPosition = "CENTER",
                           PLD_Shape              = "ROUND",
                           PLD_GroupPosition      = 0x8,
                           PLD_Bay                = 0x0,
                           PLD_Rotation           = 0x0,
                           PLD_Order              = 0x0,
                           PLD_VerticalOffset     = 0xC3,
                           PLD_HorizontalOffset   = 0xC3)
                   Device (CAMA)
                           0xFF,
                           0xFF,
                           Zero,
                           Zero
                           ToPLD (
                               PLD_Revision           = 0x2,
                               PLD_Red                = 0x0,
                               PLD_Green              = 0x0,
                               PLD_Blue               = 0x0,
                               PLD_Width              = 0x0,
                               PLD_Height             = 0x0,
                               PLD_Dock               = 0x0,
                               PLD_Lid                = 0x1,
                               PLD_Bay                = 0x0,
                               PLD_Rotation           = 0x0,
                               PLD_Order              = 0x0,
               Device (HSP8)
                   Name (_ADR, 0x08)  // _ADR: Address
                       Zero,
                       Zero,
                       Zero,
                       Zero
               Device (HSP9)
                   Name (_ADR, 0x09)  // _ADR: Address
                       Zero,
                       Zero,
                       Zero,
                       Zero
               Device (HS10)
                   Name (_ADR, 0x0A)  // _ADR: Address
                       0xFF,
                       0xFF,
                       Zero,
                       Zero
                       ToPLD (
                           PLD_Revision           = 0x2,
                           PLD_Red                = 0x0,
                           PLD_Green              = 0x0,
                           PLD_Blue               = 0x0,
                           PLD_Width              = 0x0,
                           PLD_Height             = 0x0,
                           PLD_Dock               = 0x0,
                           PLD_Lid                = 0x0,
                           PLD_Panel              = "RIGHT",
                           PLD_VerticalPosition   = "CENTER",
                           PLD_HorizontalPosition = "RIGHT",
                           PLD_GroupPosition      = 0x9,
                           PLD_Bay                = 0x0,
                           PLD_Rotation           = 0x0,
                           PLD_Order              = 0x0,
                       Return (0x03)
                       Return (0x03)
               Device (SSP1)
                   Method (_ADR, 0, NotSerialized)  // _ADR: Address
                       Return ((SSPA () + Zero))
                       0xFF,
                       0x03,
                       Zero,
                       Zero
                       ToPLD (
                           PLD_Revision           = 0x2,
                           PLD_Red                = 0x0,
                           PLD_Green              = 0x0,
                           PLD_Blue               = 0x0,
                           PLD_Width              = 0x0,
                           PLD_Height             = 0x0,
                           PLD_Dock               = 0x0,
                           PLD_Lid                = 0x0,
                           PLD_Bay                = 0x0,
                           PLD_Rotation           = 0x0,
                           PLD_Order              = 0x0,
               Device (SSP2)
                       Return ((SSPA () + One))
                       0xFF,
                       0x03,
                       Zero,
                       Zero
                       ToPLD (
                           PLD_Revision           = 0x2,
                           PLD_Red                = 0x0,
                           PLD_Green              = 0x0,
                           PLD_Blue               = 0x0,
                           PLD_Width              = 0x0,
                           PLD_Height             = 0x0,
                           PLD_Dock               = 0x0,
                           PLD_Lid                = 0x0,
                           PLD_Bay                = 0x0,
                           PLD_Rotation           = 0x0,
                           PLD_Order              = 0x0,
               Device (SSP3)
                       Return ((SSPA () + 0x02))
                       Zero,
                       Zero,
                       Zero,
                       Zero
               Device (SSP4)
                       Return ((SSPA () + 0x03))
                       Zero,
                       Zero,
                       Zero,
                       Zero
               Device (SSP5)
                       Return ((SSPA () + 0x04))
                       Zero,
                       Zero,
                       Zero,
                       Zero
               Device (SSP6)
                       Return ((SSPA () + 0x05))
                       Zero,
                       Zero,
                       Zero,
                       Zero
           Method (_DSM, 4, NotSerialized)  // _DSM: Device-Specific Method
               If ((Arg2 == Zero))
                   Return (Buffer (One)
                        0x03                                             // .
               Return (Package (0x16)
                   "AAPL,slot-name",
                   "Built In",
                   "name",
                   "Intel USB Controller",
                   "device_type",
                   Buffer (0x0F)
                       "USB Controller"
                   "model",
                   Buffer (0x3B)
                       "Intel Corporation, Cannon Point-LP USB 3.1 xHCI Controller"
                   "subsystem-id",
                   Buffer (0x04)
                        0x70, 0x72, 0x00, 0x00                           // pr..
                   "subsystem-vendor-id",
                   Buffer (0x04)
                        0x86, 0x80, 0x00, 0x00                           // ....
                   "AAPL,current-available",
                   0x0834,
                   "AAPL,current-extra",
                   0x0898,
                   "AAPL,current-extra-in-sleep",
                   0x0640,
                   "AAPL,device-internal",
                   0x02,
                   "AAPL,max-port-current-in-sleep",
                   0x0834
[ref]rositaott[/ref], with this way u don't need rename, work with a real native way ;)
sorry for stupid question, but how to apply this patch :mrgreen:
Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
[ref]rositaott[/ref], extract one send_me, i'll check ur case
Added in 38 minutes 10 seconds:
[ref]rositaott[/ref], Arquivo Comprimido.zip
in ur case all returns GUPC is enable, i just changed connectors to usb3, check if work, remove usbinjectall
Thanks for your great work, I always have a good working hackintosh machine even I don't have expensive one :mrgreen: ,because of your ussal and kind support...enjoy your beer :guitar:guitar:guitar
[ref]rositaott[/ref], :guitar:guitar:guitar
[ref]janjao[/ref], só seguir o tutorial, veja se é no dsdt ou em alguma ssdt
Hi can you please help look at my dsdt for native USB fix for dell precision m6800. Here is the link for the send me file :https://drive.google.com/file/d/1kDWVtp7eS_NwvwqDfGpLQJkD8khM6jkl/view?usp=sharing. Thanks for your assistance.
u have a native usb, just rename embedded controller to ec
Thanks for your reply. In my config I have this Rename ECDV to EC__ Find (45434456) Replace (45435F5F). Is that all I need to do?. Also have the USBportmap kext. Do I delete that? If not so, can you please make the necessary changes for me and revert?. Thanks
ECDV to EC
u need check what ur embedded controller and rename to ec
1 hour ago, Zyon said:
Thanks for help
Try it
OC.zip
8 minutes ago, Zyon said:
Thanks but not working :s
last oc version? try it
EFI.zip
Thanks !!!
So much better :)
Boot is very faster with no text :)
But sleep mode stay screen (like frozen), need to reset computer :s
I just disable sleep disk and just keep display sleep
Edit: Just see I have no internal sound card used by "jack" only usb card or HMI via screen
Edited by Zyon
https://www.olarila.com/topic/6074-guide-easy-audio-solution-with-applealc/
Just now, Zyon said:
Yes i've try it but no succes :sAppleACL.png.zip
And sorry i just see i'm on notebook topic not in desktop ...
extract new send_me
