hi i just sucessfuly install my first hackintosh mojave
my specs are gigabyte b360m, intel core i5 8400, rx560 4gb, 8gb ram, and 256 nvme.
after fresh install everything works perfect, audio, graphic card both intel UHD 630 and rx 560 is detected.
but after a few boots to the system. everything runs very sloow, even opening google crome take atleast 20 seconds, my storage is only used 50gb, since its still fresh install. then i try to run videoproc, everything starts getting worse. the app freeze when i try to se what card is running. clicking in finder also lags and stuter. im running the imac 18,1 SMBIOS..
anyone can help, maybe im doing something wrong?
thankyou
[ref]yujinks[/ref], post one full dump
--Run_Me
RunMe.app
[ref]yujinks[/ref], post file created in ur desktop here
only paypal :ugeek:
[ref]yujinks[/ref], DSDT.aml.zip
put file in clover/acpi/patched
ur config is correct, intelquicksync is working
[ref]yujinks[/ref], <IMGUR id="as3hAdO"><a href=https://i.imgur.com/as3hAdO.png' alt='IMGUR>'>
[ref]yujinks[/ref], extract new send_me
--Run_Me
RunMe.app
[ref]yujinks[/ref], u need use a folder from Olarila, correct config for all chipsets
Pasta Sem Título.zip
