Problem with Internet on my Hackintosh and with Dual Boot
[ref]kaniska[/ref], ur gpu work, but work at x4 band, u need a x16
<IMGUR id="pE7RPHI"><a href=https://i.imgur.com/pE7RPHI.png' alt='IMGUR>'>
put ur gpu in first slot
Do I need to put the gpu in the first PCI Express slot? So I need to change the hardware location? Nothing to do with the software right?
[ref]kaniska[/ref], yes, pcie x16 slot, first slot for gpu
Ok today I’m going to try. But does this mean that even on my windows pc the gpu is running at 4x?
Hello, I did what you told me to. I put my graphic card in the first PCIe slot available In my mobo (which is the second one, the first one is for wireless adapter). MacOS seems to be a lot smoother but graphic glitches and the problems with your code and olarilla repair permission.command are still there. So I'm going to send you another full dump to see if the problem of the 4x band is gone or is still there.
Send me Lucas-iMac.home-life.hub.zip
[ref]kaniska[/ref], Good Now
NVIDIA GeForce GTX 1060 6GB:
 Modelo do Chipset:	NVIDIA GeForce GTX 1060 6GB
 Tipo:	GPU
 Barramento:	PCIe
 Slot:	PCI Slot 0
 Largura de Banda PCIe:	x16
 VRAM (Total):	6 GB
 Fornecedor:	NVIDIA (0x10de)
 ID do Dispositivo:	0x1c03
 ID da Revisão:	0x00a1
 Revisão da ROM:	VBIOS 86.06.63.00.62
 Tipo:	GPU
 Barramento:	PCIe
 Slot:	PCI Slot 0
 VRAM (Total):	6 GB
Nice, but i'm still getting the same errors, is there something i can do?
[ref]kaniska[/ref], is a glitches?
if yees, u need check csm option in bios/uefi config, 1060 have this problem under macos
I'm gonna check
Hello, csm was enabled... is there something more I can do?? Otherwise I wouldn’t be able to use Macos at all... later I’ll try to send you a video but EVERY application is glitched except preinstalled apps...
[ref]kaniska[/ref], if stay enable, try disable
[ref]kaniska[/ref], ur video is activate? u have a qe/ci?
[ref]kaniska[/ref], extract send_me
i'll check
--Run_Me
RunMe.app
i'll check
--Run_Me
RunMe.app
Hello, here I am after 12 day from your last message xD. So... I had to enable cam option because of too many problems with my windows disk... I couldn't boot It at all. So here we are again with the same problems...I'm going to send you the rune file anyway
[ref]kaniska[/ref], video is ok
