Problem with Internet on my Hackintosh and with Dual Boot
[ref]kaniska[/ref], have a way, check in google, mount efi windows
Hello! I did as you said. I re-installed MacOS and i replaced the efi folder with the downloaded one. (I downloaded this folder https://Olarila.com/files/Clover.Folder/CLOVER.SERIES.100.200.300.zip because i've got i5-7600k)
Apparenlty everything worked fine, both windows and mac booted up...until i rebooted the system to check again if everything worked completley right. Now windows boots up perfectly, but again, MacOS give me problems... here are the screenshots;
Here i try to boot MacOS but during the loading everything seemes freezed here:
https://imgur.com/a/utErR9R
But after a few minutes the screen became like this:
https://imgur.com/a/Xs4DSol
I tried a few times but everytime i've got the same results...
[ref]kaniska[/ref], first update ur bios/uefi to last version, after send _me files
--Run_Me
RunMe.app
Hello. I had a lot of problems and I couldn't keep trying with this hackintosh. But today I tried again and I think this would be the last time... I got the runmeapp file and I'm going to send it.
Send me Lucas-iMac.home-life.hub.zip
Added in 12 minutes 42 seconds:
I got internet by using a router repeater with ethernet but I still got more problems...like the hackintosh is laggy and sometimes glitched... it says that I've got 7mb of VRAM but I've got a GTX GeForce 1060 6GB, what can I do to make the hackintosh smoother and possibly install Nvidia drivers?
[ref]kaniska[/ref], use only this efi and install web driver
EFI.zip
put ur gpu in first slot x16
EFI.zip
Where can I install web drivers
[ref]kaniska[/ref], check NvidiaWeb in ur config.plist, System, Parameters tab
run in terminal
sudo rm -f /System/Library/Caches/com.apple.kext.caches/Startup/kernelcache && sudo kextcache -i / && sudo touch /System/Library/Extensions && sudo kextcache -u / && sudo update_dyld_shared_cache -force && sudo nvram -c && sudo purge
reboot
I get this: Error clearing firmware variables: (iokit/common) not permitted
[ref]kaniska[/ref], is common, nvidia install kexts in system folder
[ref]kaniska[/ref], just install web driver, check NvidiaWeb in ur config.plist and run OlarilaRepairPermissions, reboot
[ref]kaniska[/ref], idk what happens
[ref]kaniska[/ref], post one full dump, i'll check
RunMe.app
