Problem with Internet on my Hackintosh and with Dual Boot
Hello, i'm a new user and this Hackintosh is the first one i ever made, so i'm a complete ignorant about this topic.
I followed the tutorial and i tought that everything worked fine, until i noticed that i couldn't connect to any internet connection. It seems that the MacOS doesn't recognize my network adapter.
I searched everywhere for any possible solution but nothing. I just can't use internet. (P.S. my modem is far away from my pc so i can't use an ethernet port, the only way to use internet for me is with a network adapter)
I can't really remember the exact model of my Network Adapter, i just know that it's made by TP-Link. Is there any fix for this isssue? I spent a lot of time to make this hackintosh and i would like to keep it instead of deleating hours and hours of research. Thanks in advance for the help.
[ref]kaniska[/ref], what wifi or lan card?
[ref]kaniska[/ref], or pcie with support or usb with support
Ok thanks, but i've got one more problem. I totally forgot to put it in the post xD.
I've got a problem with the bootloader. When i boot mac os from the usb drive it works fine, but windows does not work. I've got around 9 windows icons in clover and any of them works. The only way to start windows is by closing clover. Also, when i remove the usb drive, clover boots up, but i can't get access to any of the os in it. I can't use mac and windows as well, and i can only access windows by doing the same thing as before. Is there something i can do about this?
[ref]kaniska[/ref], check if have a EFI or SYSTEM RESERVED entries at clover boot screen
Yes, i've got 2 System Reserved and 0 efi apparently. All of the other icons says "Boot windows from" and two "boot windows from volume"
[ref]kaniska[/ref], if u use uefi mode, windows boot is EFI entrie, if u use legacy mode windows boot is system reserved
I
tried again to boot windows from “reserved for the system” but this happens:
93D412E2-7399-4FC5-90FF-5C4EE5C97283.MOV
Maybe it’s because windows is one another disk? Or because i’m trying To boot it with my usb drive still in?
Added in 18 minutes 4 seconds:
I tried again to boot windows from “reserved for the system” but this happens:
UPDATE!
Apparenlty MacOS Mojave stopped working even by booting it from the original usb drive...here's a screenshot of the error:
https://imgur.com/a/nrixxtZ
What should i do? Should i try to install it again?
I checked in the boot option of my mobo and if i remove the usb drive, the main boot option is this one:
https://imgur.com/a/FGbHeC8
This option boot me into clover, but it's a strange version. Instead of getting the usual Olarila dark theme, i get the white clover theme with all mac icons corrupted:
https://imgur.com/a/Ed9Pqn0
If i try to boot windows from here i get the same screen that i mentioned in the previous post, but if i try to start the corrupted mac os (from the disk where the os should be installed) i get a complete black screen:
https://imgur.com/a/PA57lXL
Can someone please help me out? I'm really going crazy
[ref]kaniska[/ref], remove fakesmc sensors, don't use it
[ref]kaniska[/ref], u need check where u installed it
[ref]kaniska[/ref], or clover/kexts/other or library/extensions or system/library/extensioons
From what you said I think I should deactivate it from MacOS but I can’t boot into it. Should I modify this file in the usb drive? Or do I need to reinstall Mac OS in order to do this?
I did, but I can’t complete the 7th step. By downloading the new versions of Clover I don’t get those options. Have you got a link to download that specific version?
[ref]kaniska[/ref], if u use efi from here, don't need install clover, just past efi folder into efi partition
https://Olarila.com/forum/viewtopic.php?f=28&t=8222
