Strange Ethernet problem (no more internet after some time, but still "connected")
Hello!
I'm facing a problem since a few days on my Hackintosh build :
- MacOS High Sierra 10.13.6 (17G8030)
- Intel Core i5-3570K
- GA-Z77-D3H
- Radeon RX 580 4Go
The problem is : after some time my internet connexion crashes (built in Ethernet Port). In network preferences Ethernet still says "Connected" but no more internet connexion. Rebooting solve the problem.
I think this is due to huge download/upload transfert rates, which makes the driver stop working, before there was no problem (I just installed the 1Gb Optical Fiber lastweek, I had 100Mb Optical Fiber before). It happens mostly when uploading big video files with Google Drive (for my work as a videographer).
Here is the Send Me file, just in case it could help with this problem! (file too big to be send in the attachements)
https://drive.google.com/file/d/1YquIVE_amvCqOCG711jtzoBihMrT5Eq3
Thanks in advance for your help :)
MSTRKKRFT
MacOS Mojave 10.14.6 // OpenCore 0.6.8
Intel i7-9700K // GIGABYTE Z390-AORUS-Elite // MSI Vega64 8Go // Fenvi T919 // Corsair Vengeance LPX 32GB (2x16GB) 3200Mhz DDR4 // Samsung 970 EVO NVMe M.2 500Go (system) // Western Digital SN550 NVMe M.2 500Go (data) // Toshiba THNSNS SATA SSD 128Go (cache) // Kingston A400 SATA SSD 240Go (Windows 10 drive) // Western Digital WD1000FYPS SATA HDD 1To (data) x2
[ref]MSTRKKRFT[/ref], check if ur card work with mieze's kext
AtherosE2200Ethernet.kext.zip
if not, use one updated version and try
AtherosL1cEthernet.kext.zip
[ref]MaLd0n[/ref], Thank ou very much for your help!
The second solution (updated version of AtherosL1cEthernet.kext.zip) seems to work well (first solution didn't worked, no more Ethernet Connexion in Network Preferences), I'll do more tests tomorrow to be sure but I think the problem is solved :D
Have a great evening!
hellow bro sorry for disturbed i installedd success Olarila high sierra not ethernet not work and when i boot windows show black screen
i5 4590
Intel HD 4600
