Hi guys,
So this is what happen, before I installed Nvidia Driver my audio device is okay https://imgur.com/PfYAnIm but after Nvidia installation I can't connect to the Line-out (gear) because my audio is connected to the devices not in Intel High Definition audio https://imgur.com/BejRPE0
https://imgur.com/XlTk5ND
My question is how can I connect to the High Definition audio? so that I could you its Line-out (gear)
CPU: Intel® Core i5-9400F
MOBO: ECS > H310CH5-M2
GPU: Nvidia GTX 750ti
[ref]losewin[/ref], u use voodoohda? use native audio
Still not working, Already tried AppleHDA and AppleALC, but instead I got black screen after verbose logs, but I guess only the display is being broken because the keyboard are still functioning.
