Mojave 10.14.6 strange problem, MSI R9 280X
I put my EFI folder with config to attach, so you can see my settings.
I have a problem with a green screen. When I run some app, a green screen pops up before entering the app and in the apps half my screen works, on second half my mouse won't click.
This is show in about my Mac: AMD Radeon HD 7970X/8970/R9 280X 3 GB
But something won't work, something wrong.
Maybe some kext to patch ATI, anyone who know to do this?
Framebuffer is Hamachi.
https://www95.zippyshare.com/v/fwrQsp5P/file.html
Here is the video.
https://www109.zippyshare.com/v/7lzOtEWO/file.html
And then open app, but at the bottom, few inches, won't click on tab.
1061198271_ScreenShot2019-08-20at23_40_40.png.68331324138cc4de7a632348f9b9d176.png.zip
OS: macOS Mojave 10.14.6 : Intel I7 4770 3.4GHz : Asus Z97-C : Chipset: Intel® Z97 : Memory: 12096 MB : MSI Radeon R9 280X Gaming Edition (3GB DDR5) : Audio: Tahiti XT HDMI Audio ( Radeon HD7970 Series) : Ethernet: Intel® I218V : Audio Adapter: Realtek® ALC892 8-Channel High Definition Audio CODEC featuring Crystal Sound 2
[ref]Iwanche[/ref], u have all hackintosh kexts update?
Yes, all kext is new..
[ref]Iwanche[/ref], check in weg github if have some info about ur gpu
I searched, but didn't find a solution.
Any help with kext to patch? Framebuffer is Hamachi, i have a four video port, 2 dp, one hdmi, and one dvi. Attached to hdmi port, sound work, but only problem is a green screen when i start some application, and then in the bottom bar I can't click anything.
Added in 7 minutes 54 seconds:
Can you put this code to my DSDT.aml, but changed Buffer name to Hamachi and see if connector is good.
This is line from 2015, probably old mac os.
into device label PEG0 insert begin
Device (GFX0)\n
{\n
Name (_ADR, Zero)\n
Name (_SUN, One)\n
{\n
Store (Package (0x1A) {\n
"AAPL,slot-name", "Slot-1",\n
"name", "Display Controller",\n
"device-id", Buffer (0x04) {0x98, 0x67, 0x00, 0x00},\n
"@0,connector-type", Buffer (0x04) {0x00, 0x08, 0x00, 0x00},\n
"@1,connector-type", Buffer (0x04) {0x00, 0x08, 0x00, 0x00},\n
"@2,connector-type", Buffer (0x04) {0x00, 0x08, 0x00, 0x00},\n
"@3,connector-type", Buffer (0x04) {0x00, 0x08, 0x00, 0x00},\n
"@0,name", Buffer (0x0F) {"ATY,Aji"},\n
"@1,name", Buffer (0x0F) {"ATY,Aji"},\n
"@2,name", Buffer (0x0F) {"ATY,Aji"},\n
"@3,name", Buffer (0x0F) {"ATY,Aji"},\n
"model", Buffer (0x13) {"AMD Radeon R9 280X"},\n
"hda-gfx", Buffer (0x0A) {"onboard-1"}\n
}, Local0)\n
Return (Local0)\n
}\n
}\n
end;
Device (HDAU)\n
{\n
Name (_ADR, One)\n
{\n
Store (Package (0x02) {\n
}, Local0)\n
Return (Local0)\n
}\n
}\n
end;
[ref]Iwanche[/ref], weg kext and clover have a easy way for it, inject feamebuffer via clover
Ok, i have installed weg kext, inject framebuffer via clover, but same thing. I put FB name Hamachi, ati inject, load vbios, radeon deinit, but green screen again.
Any specific clover settings?
Can you give me a config.plist for my specification? I have your DSDT.aml to me. And i also have some SSDT.aml.
[ref]Iwanche[/ref], check Olarila clover folder for ur chipset
I do it everything, but won't help..
System Info
Host Ivans-iMac.local
OS macOS Mojave Version 10.14.6 (Build 18G87)
Kernel Darwin 18.7.0 x86_64
RAM 12.00 GB
Model Identifier iMac15,1
CPU Intel® Core i7-4770 CPU @ 3.40GHz
Intel Generation ???
Platform ID 0x00000000
VDA Decoder Decoder Failed
GFX0
GPU Name Tahiti XT [Radeon HD 7970/8970 OEM / R9 280X]
GPU Device ID 0x67981002
Quartz Extreme (QE/CI) Yes
Metal Supported Yes
Metal Device Name AMD Radeon HD Tahiti XT Prototype
Metal Default Device Yes
Metal Low Power No
Metal Headless No
[ref]Iwanche[/ref], iff u need a correct config for both GPUs(internal and dgpu) u need enable intel graphics in bios/uefi setup and correct config
https://Olarila.com/forum/viewtopic.php?f=62&t=7164
Intel graphic is enabled in bios/uefi, but won't work..In bios boot graphic set auto..
