Help ..i need compiled my dsdt for snow leopard on my gigabyte z68 ud7 , i use null cpu for this . Maybe i need modified DSDT for speed step and delete Null ????
For OLD , i see your post this message
NullCPUPowerManagement.kext - Desativa a AppleIntelCPUPowerManagement.kext, necessária até que você modifique o DSDT para suportar SpeedStep nativo.
:mrgreen::mrgreen: Without PC :mrgreen::mrgreen:
You can use Chameleon's Generate PStates & CStates, or create an SSDT.aml instead of patching DSDT for this.
Compare iMac12_x.plist in Snow and Lion (/System/Library/Extensions/IOPlatformPluginFamily.kext/Contents/PlugIns/ACPI_SMC_PlatformPlugin.kext/Contents/Resources).
nope..there is not
Try to put the plist for your Mac model in ACPI_SMC_PlatformPlugin.kext/Contents/Resources
Hi Old ..i try your first file..score geekbench is high again
only this error in kernel log
Dec 16 18:30:31 localhost kernel[0]: ACPI_SMC_CtrlLoop::loadStepperProgram - pmCPUControl (PMIOCSETPSTATESTEPPER) failed, result = 0x4
Try with the other plist, and without any plist for your Mac model.
Remember to update caches.
whit the second file , that you editated from imac 12.2 , dont have error in kernel log
Ok?
I use this ,definitive?
Or use the original iMac12_2.plist and set iMac12,2 in SMBIOS.
Just change iMac12,1 to iMac12,2
<key>iMac12,2</key>
Right click - show package contents
Edit Info.plist
Edit - find: iMac12
Try npci=0x2000 (type at boot prompt or put in kernel flags in Boot.plist).
