problems on Mojave 10.14.6 installing on Lenovo Ideapad 110
i created Installer for Lenovo Ideapad 110 (skylake) but i can just format HDD to HSF+ and no APFS available to choose :shock: , after install and first boot there is no Boot From to Mojave. :( actually i have only boot to Mojave Installer in clover. i use clover for notebooks 100 200 300 series.
[ref]pi2in3[/ref], what?
is a hdd or ssd?
is a hdd or ssd?
. Its HDD
Added in 6 minutes 20 seconds:
i boot to Installer , install mojave on HSF+ cause no APFS to choose in DiskUtility. installing process takes 15min then reboots and boot to USB Clover but doesnt show Boot to Moajve (which i installed to). the only option is Boot to Mojave Installer. i'm sorry for my worse English :D
[ref]pi2in3[/ref], use ssd
i installed Mojave successfully. now i cant install Audi driver i tried many ways (voodoHDA, AppleHDA patcher, .... ) but doesn't work. its a Conexant CX20751/2.
add gestures to my Trackpad
Is track pad working? What device do you have? I2C? PS2?
control display brightness?
? If you mean to make brightness hotkeys work https://Olarila.com/forum/viewtopic.php?f=28&t=8396
Donate
Gitter Chat
MSI B360 Gaming Arctic
yes but one more thing i have no brightness bar in system preferences > display (link below 16:50)
Yes working but no smart gestures. i don't know which one is(PS2 or I2C)
also i don't have Apple Track-pad . actually i meant Mouse-pad which laptop already has. i want OS recognize it as a track-pad with gestures working
(17:07)
addPNLF at clover or Add PNLF patch at DSDT and use Whatevergreen + Lilu kexts
what kext are you using? Check device in Windows Device Manager. Cant help further if you cant tell the device type.
Is your battery indicator working?
Donate
Gitter Chat
both KB and Track-pad are P/S2. i added addPNLF in Fixes section of config.plist->ACPI now i have brightness bar, thanks.
just 3fingers works(as right-click)
my kexts:
WEgreen
Lilu
AppleALC
ACPIBatterManager
ApplePS2SmartTouchPad
NoTouchID
NullCPUPoowerManagement
USBInjectAll
SATA-Raid_Usupported
SATA-Unsupported
Voodool2CHID
Voodool2C
VoodooPS2Controller
VoodooPS2Keyboard
VoodooPS2Trackpad
VoodooTSCSync
XHCI-unsupported
AirportBrcmFixup
AtherosE2200Ethernet
RealTekRTL8111
RealTekRTL8100
These should just work with either voodoops2controller kext or ApplePS2SmartTouchPad. You should be able to tell from ioreg which kext are being used by your trackpad.
You do not need voodooI2c kexts.
I have no idea why you have VoodooPS2Keyboard & VoodooPS2Trackpad kexts out in others folder as these kexts are used as plugins to voodoops2controller.
https://imgur.com/7tj0rVG
Solve your battery indicator and track pad preferences should show (at least this is true for I2C devices).
Donate
Gitter Chat
i deleted voodool2C* kexts and voodooPS2* kexts but voodooPS2Controller. but no changes then i decided to delete ApplePS2SmartTouchPad but mac didn't boot.
i have no issue with Battery indicator.
IOReg output file is attached.
Ho3in’s MacBook Pro.zip
[ref]pi2in3[/ref], i will check your files later when i get home. But, deleting smartouchpad shld not cause issues in booting. I hope you are uploading runme files or debug script and not just your Dsdt or EFI folder. Thanks
Donate
Gitter Chat
thanks for help, here is all necessary files.
Send me Ho3ins-MacBook-Pro.zip
[ref]pi2in3[/ref], From here, your track pad is using Emily Dinesh's ApplePS2SmartTouchPad. This is a very old but still functional kext I suppose. Read up more on the kext's supported gestures here https://osxlatitude.com/forums/topic/1948-elan-focaltech-and-synaptics-smart-touchpad-driver-mac-os-x/
https://imgur.com/OpfMmXV
So, with that you wont be needing the following kexts (so delete them)
a. NoTouchID
b. Voodool2CHID
c. Voodool2C
d. VoodooPs2Controller (ApplePS2SmartTouchPad also comes with supported keyboard controller)
2. In addition, your ethernet is RealTekRTL8100. So you can delete the below kexts, too.
https://imgur.com/SxVY40q
a. AtherosE2200Ethernet
b. RealTekRTL8111
3. I see you do not have any supported Broadcom Wifi card, delete this too.
a. AirportBrcmFixup
4. You may also safely remove the below kexts
a. XHCI-unsupported
b. SATA-Raid_Usupported
c. SATA-Unsupported
d. NullCPUPowerManagement
For a better hackintosh experience, you may want to patch your DSDT. Press F4 at Clover boot loader (to extract ACPI tables to ACPI/Origin) and extract new RunME files.
That's all I have to say for now.
Donate
Gitter Chat
i deleted all kexts you mentioned. no touchpad settings but at least 2fingers and 3fingers gestures works. i'm giving up by that.
i attached new RunMe app folder would you patch it for me? is it so hard to learn patching DSDT?
Send me Ho3ins.zip
[ref]pi2in3[/ref], Check if work and extract new sendme for checks. Place file in Clover/ACPI/Patched folder.
Use only these patches in Clover.
change GFX0 to IGPU
change HECI to IMEI
change SAT0 to SATA
change HDAS to HDEF
Delete VoodooTSCSync.kext If you can boot without it.
Also delete IntelMausi kext. You don't need it.
Donate
Gitter Chat
[ref]pi2in3[/ref], Use only these patches in Clover.
change GFX0 to IGPU
change HECI to IMEI
change SAT0 to SATA
change HDAS to HDEF
i found those patchs in Acpi -> DSDT and disabled others. what about kernel and kernel patches?
