[Help] X79 - Fully working other than RX580
Hi guys,
Just installed Mojave and I have a fully working build with the exception of my GPU. Even iMessage is good.
My GPU is fine with a single display, however if I add multiple, I loose acceleration and the secondary display just flickers. Also, the only ports that work are the 2 display ports. I am trying to run 4 displays (2 HDMI, 1 DVI, 1 Display port). I have a Sapphire nitro+ 8GB RX580
Other specs
MSI X79A-GD65 (8d)
i7 3970x
32GB Corsair Vengeance
Corsair RM650 PSU
Corsair H100i
2x Intel Datacenter 120GB SSD
1x Samsung 860 Evo SSD
1x Seagate 4TB SSHD
Any advice here? Will post a full guide/pics in working hacks when this is sorted :)
[ref]infasyn[/ref], last whatevergreen version?
[ref]infasyn[/ref],
post full dump
--Run_Me
RunMe.app
Sure, ill get back to you in a little bit. Nicked my SSD to try a different system so don't have that install running atm
[ref]infasyn[/ref],
EFI.zip
folder only for uefi mode, use only it, check if have CSM option on bios/uefi
Thanks man, ill try it now. Yeah my bios has Legacy & UEFI enabled, currently booting efi
Added in 7 minutes 51 seconds:
[ref]MaLd0n[/ref],
Alrighty so I tried booting with that and I didn't boot at all, it got stuck on
"FireWire (OHCI)" etc (pic attached)
67183462_394312824525651_4407775007166431232_n.jpg?_nc_cat=109&_nc_oc=AQkznilvXfcnZCQv_K6dWjvQhghSbuKyWX8_JGr2tticqEJJVEvbcZmGwJanvM3rA-c&_nc_ht=scontent-lhr3-1.xx&oh=f76d7d2147cc9c081723fda47764bed5&oe=5DB9BCDA
[ref]infasyn[/ref], have csm option in bios?
[ref]MaLd0n[/ref],
Closest I have is "legacy + UEFI" or "UEFI Only" in my boot options. I don't see CSM anywhere.
Mac OS, Windows and Linux will boot with either option selected.
[ref]infasyn[/ref], uefi only
[ref]MaLd0n[/ref], Yup thats what im running, still only able to use 1 display
Added in 4 minutes 20 seconds:
[ref]MaLd0n[/ref],
Spent another few hours trying various patches and still no luck.
Do you think it would be worth trying either 10.13 or 10.15?
[ref]infasyn[/ref], u try other combinations? like dp/dvi, hdmi, dvi...
