Administrators MaLd0n Posted October 12, 2021 Author Administrators Posted October 12, 2021 6 hours ago, Vitxuxo said: Opa qual o processador? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Nenad Nenad Posted October 16, 2021 Posted October 16, 2021 i installed catalina normally on hp6300 and then i bought a new ssd and wanted to reinstall however it gives me an error as in the picture. unnamed.rar
Administrators MaLd0n Posted October 16, 2021 Author Administrators Posted October 16, 2021 1 hour ago, Nenad Nenad said: i installed catalina normally on hp6300 and then i bought a new ssd and wanted to reinstall however it gives me an error as in the picture. use usb2 port -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
rositaott Posted October 18, 2021 Posted October 18, 2021 currently have macOS BigSur and tried to install MacOS Monterey on my pc but after the first installation stage, I choose macOS installer then boot to Mac OS recovery and no option to continue installation. Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
Administrators MaLd0n Posted October 18, 2021 Author Administrators Posted October 18, 2021 35 minutes ago, rositaott said: and no option to continue installation. last opencore and kexts version? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
rositaott Posted October 19, 2021 Posted October 19, 2021 (edited) 8 hours ago, MaLd0n said: last opencore and kexts version? use the EFI folder from this link https://tinyurl.com/xwebycub EDIT: tried to reinstall today and finally got it working, dual booting and testing now BigSur and Monterey Edited October 19, 2021 by rositaott 1 Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
josieco Posted November 2, 2021 Posted November 2, 2021 (edited) Maldon blz? Me ajuda ae por favor! Tenho o Big Sur instalado certinho no meu SSD e abrí um container nesse mesmo SSD pra instalar o Monterey baixado na Applestore. Até consigo instalar depois de uns 90 minutos pois dá muito iokit daemon stall no ´IOUSBHostdevice´. Depois já dentro do OS ele não mostra nenhum HD nem pendrive nem disco externo, apenas o SSD com o Big Sur e o próprio Monterey. Tem momentos de lentidão e o system preferences trava às vezes. Baixei sua imagem mas após carregar o modo verbose, não mostra nenhum HD no disk utility, apenas o pendrive, aí tenho que abortar. Já dei um default na bios e quando entro no Big Sur tá tudo funcionando certinho, mas quando entro no Monterey, já começa pela demora de cerca de 5 minutos, depois começa algumas travadas pra abrir alguns apps e sou forçado a fechar um ou outro. Queria instalar sua imagem pelo pendrive, já tá prontinha aqui. Poderia me ajudar? Vou ver se consigo te mandar minha config.plist. Desde já te agradeço mais uma vez! config.plist.zip Edited November 2, 2021 by josieco
Administrators MaLd0n Posted November 2, 2021 Author Administrators Posted November 2, 2021 https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
josieco Posted November 4, 2021 Posted November 4, 2021 On 11/2/2021 at 3:52 PM, MaLd0n said: https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/ Tentei sua pasta de efi mas também não encontra meus hds no utilitário de disco do instalador. Já dentro do sistema já instalado, não aparece nem o pendrive com a imagem Monterey do Olarila. Quando entro no Big Sur funciona tudo! Poderia me montar uma efi folder pro Monterey com minhas peças por favor? Me passa o valor de quanto fica que eu faço um donation. Segue minhas specs: Mobo: Msi z390 a-pro Cpu: i7 8700T Gpu: Asus RX580 4gb (Elesmere) A memória é de 32gb de 2666mhz O restante, som, rede, wifi, bluetooth eu me viro aqui, Tô usando as kexts do Big Sur e só o que não tá funcionando é o bluetooth. o Tuxera também não funciona. Me ajuda ae por favor?
Administrators MaLd0n Posted November 4, 2021 Author Administrators Posted November 4, 2021 8 minutes ago, josieco said: Tentei sua pasta de efi mas também não encontra meus hds no utilitário de disco do instalador. Já dentro do sistema já instalado, não aparece nem o pendrive com a imagem Monterey do Olarila. Quando entro no Big Sur funciona tudo! Veja aqui https://www.olarila.com/topic/7717-important-premium-and-donators-users/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Robson_muniz Posted November 30, 2021 Posted November 30, 2021 I downloaded the Monterey image here and it's working normally, however when I boot it always starts in verbose mode instead of apple, what can I do to solve this?
Administrators MaLd0n Posted November 30, 2021 Author Administrators Posted November 30, 2021 2 hours ago, Robson_muniz said: I downloaded the Monterey image here and it's working normally, however when I boot it always starts in verbose mode instead of apple, what can I do to solve this? remove -v and reset nvram -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Robson_muniz Posted December 1, 2021 Posted December 1, 2021 22 hours ago, MaLd0n said: remove -v and reset nvram I'm sorry I'm a new hackintosher... How can I "remove the "-v"? I remove it from where? How?
Administrators MaLd0n Posted December 1, 2021 Author Administrators Posted December 1, 2021 bootargs -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
