I use 2 monitors but when booting fails, the following cannot be entered
I use the connection DP for Dell U2312 and DVI for LG 27MP35
all 1920x1080
Main : Asus B360 F Gaming
CPU: i5-8400
Vga: GTX 980Ti
My Os: 10.13.6 (17G7024)
Please fix help me!
Thanks you
CLOVER.zip
[ref]meliodasu[/ref], csm is enable, for multi monitors in some cases need it
I couldn't boot into it, I had to disconnect a screen to boot into macos then plug it back in
