Hi, anyone here experienced with 0% battery stucks?
on the feb 2019, i got help from reHab, and the battery seems still stucks on 0% like this
view?usp=sharing
then i try to dump file by my self, and try fix thru the guide from rehab. fix the batre with N55SL patch, its show no error on macisl, and boot well no acpi error on verbose mode, but the kext wont load properly, sound wifi etc wont work..
any word would be helpfull, andplease help me to fix this, thankyou!
heres my spec
Asus K401LB, i5-5200, 6gigs of ram, 1tb hardisk, ar9285
Added in 7 minutes 9 seconds:
help by @maldon, my mistakes
Added in 2 minutes 48 seconds:
help by @mald0n,
my mistakes
Send me Faizuddins-MacBook-Pro.zip
my-DSDT.aml.zip
rehabfix-DSDT.aml.zip
P_20190506_201156.jpg.zip
