Hi There,
I am using an EFI of the nearest Thinkpad model to the X280 , which is the Thinkpad T480.
It is almost perfect and almost everything seems to be working with the same ssdt files and the clover DSDT Patches in config.plist
The only things that are not detected are the thunderbolt ports (work as usb-c)
and the battery , the t480 has 2 batteries whereas the x280 only has one, which
is not showingat all. Everything is 0 and no battery status indicator possible.
Could anyone please help???
It will be a perfect machine once this problem is sorted out.
Many Thanks
Jack
Send me Jacks-MBP.zip
[ref]niteman1969[/ref],
1. Place DSDT.aml in Clover/ACPI/Patched
2. Remove SSDT-BAT and SSDT-BATC
3. Reboot and see if battery works.
Donate
Gitter Chat
MSI B360 Gaming Arctic
Hi , and thank you for your help, unfortunately it didn't work.
I tried it with and without acpibatterymanager.kext and smcbatterymanager.kext individually
I did delete ssd-bat.aml and ssd-batc.aml and nothing changed.
I then tried disabling the notifies for battc on acpi tab on clover.
I'm stumped.
Many Thanks
Jack
Need to check your osi patch or ssdt has windows patch.
I also took a look at your clover config and found there are multiple hot patches for battery status. Remove all hot patches concerning battery and try again.
Can you generate fresh ACPI tables by pressing F4 at clover bootloader and upload clover/acpi/origin folder?
Donate
Gitter Chat
[ref]niteman1969[/ref], boot only with these files. see if works.
Archive.zip
Donate
Gitter Chat
Hi There, just get the no entry sign immediately after apple logo. I deleted all the other ssts, should I be trying with Fakesmc instead of virtualsmc?
add -v in boot arg to see what is causing the problem.
I am also not a fan of installing kexts in S/L/E or L/E. Use only clover/kexts/other folder for its purpose. Download a generic clover folder here and use it as well https://Olarila.com/files/Clover.Folder/CLOVER.NOTEBOOKS.100.200.300.zip.
Upon reboot, generate a new RunMe file.
Donate
Gitter Chat
Need expert help with your Hackintosh?
Get professional Olarila support for:
Support us - Donate HERE
