hi every one , i installed Hackintosh Mojave on my laptop but audio files and internet doesn't work yet . did any one know how to solve this problem
[ref]yissmail1[/ref], what ur internet card and audio codec?
Mald0n, this data i brought from device manager.
sound:
Realtek,High Definition audio
audio:
Microphone(Realtek,High Definition audio)
Speaker/HP(Realtek,High Definition audio)
NetWork:
Bluetooth Device(Personal Area Network)
intel® Wirelss-N7560
RealTek PCle FE Family Controller
Wan Miniport (LKEv2)
Wan Miniport(ip)
Wan Miniport(ipv6)
Wan Miniport(L2TP)
Wan Miniport(Network Monitor)
Wan Miniport(PPPOE)
Wan Miniport(PPTP)
Wan Miniport(SSTP)
Display:
intel® HD Graphics Family
NIVIDIA GeForce GT 740M
[ref]yissmail1[/ref], intel wifi dont work in macos
if u have a realtek lan use it
Arquivo Comprimido.zip
thanks for help , but i want to tell me what i should do with this files ?
where i should install this file , in clover folders?
are this file will resolve the audio and internet problems?
[ref]yissmail1[/ref], clover/kexts/other, reboot
Thank you Maldon I set up hackintosh and internet now is work by cable but there are small problem that I can't connect to App Store . are hackintosh dosen't allow to connect with App Store or their are some thing wrong I should solve it
[ref]yissmail1[/ref], connect yes, no problem about it, check if u see some fixs for it in google
