[ref]dhr98[/ref], ye, is not hard
:cry::cry::cry:
Imposible to use the point 6:
6- Start a Post Installation *Go to Olarila Image/Files folder and run "disablehibernate.command"
After the macOS installation, clover start macOS and after the boot block at this point:
I have 2 SSD
one for macOS (APFS) with Clover and the second with Windows (NTFS)
My second problem, with or without the Olarila USB Key, windows don't boot again! :cry:
Only a white line on the top left for Windows 10.
MB: https://www.asus.com/ch-fr/Motherboards/ROG-STRIX-Z370-H-GAMING/specifications/
CPU I9, GPU Sapphire VEGA64, RAM 32GO
[ref]greens[/ref], disable IntelHD in bios/uefi
Primary Display is IGFX.
IGPU is disable.
RC6 (render Standby is disable)
On the UEFI from the MB, I have disable "HD AUDIO CONTROLLER",
I have plug two monitor (one with MB and the other with the VEGA64)
but it's the same problem...
IntelHD is for the graphic card? This UEFI is complicate...
Added in 35 minutes 39 seconds:
On the second moniteur the background is just gray...
Added in 3 minutes 41 seconds:
I have enable the IGPU and it's works...
No problem to boot on USB key but a reboot problem with the EFI from my M.2 SSD (with Mojave installed and it's work now :D ), I try to install Clover and remplace de folder Olarila and install again clover.
(if I don't boot from the USB key) the clover write for 2 secondes:
WELCOME TO CLOVER 5017
... SCAN ENTRIES ....
And the PC reboot all time.
I try to remplace the EFI files from the M.2 with the EFI files from the USB key and it's exactly the same result... reboot again again...
but, if I boot with the USB Key, no problem... :shock::shock::shock:
Again is the graphic card
