hello, mojave sometime boot to desktop, sometime stuck in verbose mode. what is the problem? I have patched dsdt and latest whatevergreen/lilu. Using Olarila 14.3 image and Olarila laptop config. Spec:
7700hq/intel 630
gtx 1060
[ref]raidriar[/ref], post one photo in error screen
INTEL Eight Core i9-9900K
ASUS ROG Strix Z370H GAMING
DDR4 32GB
Power: CORSAIR RM650X 80 PLUS Gold
GC: SAPPHIRE - RADEON RX VEGA 64 NITRO+
I use Olarila image with the app
I try config 2 but nothing works...
Bios setting need to change?
[ref]greens[/ref], the problem is USB, use usb 2 port or one usb 2 stick
[ref]greens[/ref], u need post photo
try with emuvariable driver, sound like a nvram problem
[ref]greens[/ref], if work, install with intelHD and put vega after
Hello mald0n, many time the verbose screen disappears and loads to Apple logo + loading bar but the immediately freezes. Last few lines of verbose usually refer to applelpssi2c controller timeout or kextd intelclientfb stall.
emuvariable driver, nvram emulate
EmuVariableUefi-64.efi.zip
okay thanks very much, i have the file but how to use it?
[ref]greens[/ref], Clover/drivers64UEFI
in the USB installer? I don't have any system on my PC, it's a new one...
Added in 50 minutes 33 seconds:
I remplace the CLOVER folder on EFI from the USB installer with this one:
https://Olarila.com/files/Clover.Folder/CLOVER.SERIES.100.200.300.zip?fbclid=IwAR2bAUSf14WdGF2bBeju3HMfTVMQZ9AP9vkYdKRpxOKu2vmPJD4BblvQA2w
but same crash during installation... (white page with ReportCrash)
now I have add EmuVariableUefi-64.efi on the clover EFI folder and the installation freeze (write 12 minutes during 1 hour and the mouse was bloked). :cry:
[ref]greens[/ref], no idea :shock:
My configuation don't work with Olarila, installation freeze maybe not compatible... I need I build my PC with the recommandation of tonycrapx86, maybe more compatible...
Added in 23 minutes 26 seconds:
Not compatible?
Olarila image Mojave 10.14.3 installation fail (repportcrash white page)
Olarila image Mojave 10.14.3 with EmuVariableUefi-64.efi (in CLOVER) installation fail (freeze installation with the message "about 12 minutes remaining...")
try with a other CLOVER folder https://Olarila.com/files/Clover.Folder/CLOVER.SERIES.100.200.300.zip?fbclid=IwAR1mHKEgeg9C2ot9IjuebJVMi-s_vhuQj8bX8znHeU4M0DHgCRRg8_DHrAM
Olarila image Mojave 10.14.3 with new CLOVER folder (repportcrash white page)
Olarila image Mojave 10.14.3 with new CLOVER folder and EmuVariableUefi-64.efi (in CLOVER) installation fail (freeze installation with the message "about 12 minutes remaining...")
[ref]greens[/ref], for installation u can use ur personal installer, the problem is post installation ;)
I think, I have a RAM problem, I have change de settings, and now clock speed is to auto a 2100 (it's kingston speed at 3200). and now with EmuVariableUefi-64.efi I have a installation fail (repportcrash white page) but no more freezing...
Hello, I have Lenovo Ideapad 500(i7-6500U, 8gb ram, AMD Radeon M360, Intel 520 graphics, 1 TB HDD), and I face same kernel panic issue during mojave installation I couldn't install OS. I follow this form for installation, https://Olarila.com/forum/viewtopic.php?f=50&t=8685 Please help me how to proceed further. if anyone helps appreciated. Thank you. Image of panic I put in this zip file.
54731294_359119031368963_350119106835382272_n.rar
MaLd0n, I already use config2.plist. I don't understand whats the problem!! There are many users have a same system and they can easily install hackintosh.
