Hackintosh Hackintool - Video Patch - Fast and Easy Solution
[ref]kutchachhikhen[/ref], i think intelhd2500 don't work in any macos
Boa tarde amigos, tenho umas dúvidas:
Seu eu aplicar esse Patch, eu mantenho a capacidade de Quick Sync com minha RX 580. Se sim, qual a vantagem em relação a esse método https://Olarila.com/forum/viewtopic.php?f=62&t=7164
Mudando o processador para um i9 9900k (lembrando que quero manter o Quick Sync com minha RX 580) continuo usando os passos descrito para Gen 8: Coffee Lake (Intel UHD Graphics 630) ou tenho que buscar outra solução?
Desde já agradeço ao constante suporte e ensinamentos.
[ref]alanzito3d[/ref], se vc usar a última versão da weg, é só ativar a intelhd, a kext hj em dia já injeta as propriedades
[ref]MaLd0n[/ref], Então eu só preciso fazer o [Guide] Hardware Encoder / Hardware Decoder / Video Processing / HEVC Support / Intel Quick Sync? Esse patch do hackintool serve somente para quem não tem GPU dedicada?
[ref]alanzito3d[/ref], não serve, não precisa
[ref]aryaone[/ref], why u need disable it? use last weg kext and let this driver work
WhateverGreen.kext.zip
Did you look at this ooooold topic? it's for *Montain Lion*
]The following method only works for OS X Mountain Lion 10.8.3 and newer
it recommends to add
device-properties
7f0000000100000001000000730000000200000002010c00d041030a000000000101060000027fff04002c0000004100410050004c002c00690067002d0070006c006100740066006f0072006d002d00690064000000080000000b006601140000006800640061002d0067006600780000000d0000006f6e626f6172642d31
to your pslist
and use multishit to go macmini6.2 in system definition
I've checked in https://everymac.com/systems/by_processor/intel-core-i5-macs.html but I can't find anything with hd 2500, good luck!
source:
http://www.macbreaker.com/2013/05/enable-hd-2500-graphics-on-your.html
Hi [ref]MaLd0n[/ref], I'm still using on-board GPU, will this be able for my VGA port to work, currently I'm connected to HDMI port, and I want to use VGA for another monitor. Tried different patches, but main display got glitched or magenta sometimes (after trial & error patching), but VGA still no output.
Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
[ref]rositaott[/ref], vga same as dp, try change connectors
[ref]rositaott[/ref], u need test, connect, disconnect cable from outputs and check with hackintool
rositaott, u need test, connect, disconnect cable from outputs and check with hackintool
problem is no other highlighted even I connect/disconnect 2nd monitor
the only port detects my 2nd monitor is index 0 with bus Id 0x00 LVDS (but i'm sure not for desktop), hoping and tried all different bus Id, downgraded to Mojave still no luck for having 2nd display on VGA port :help
[ref]rositaott[/ref], is a very personal patch, u need many test for check correct
[ref]MaLd0n[/ref], can you please take a look at my configuration which is Mojave 10.14.6, i3 7100, Gigabyte H170N board, and NVME Samsung EVO Plus, Graphic that I use is integrated intel HD 630. I have trouble with Framebuffer. Board have two HDMI and one DVI ports. I manage to patch Framebuffer with Hackintool so that both HDMi ports are working together, but DVI port I just can't get it to work. It's showing loading bar while booting, but in half loading goes off.
Second problem is that wake after sleep is not working..but that is off topic here I think
Thank you.
Send me G4s-iMac.zip
[ref]Ignis[/ref], first use a Olarila folder with correct and clean config
https://Olarila.com/forum/viewtopic.php?f=28&t=8222
apply ur video patch and extract send_me
rositaott, is a very personal patch, u need many test for check correct
yeah, I'm still trying as of this writing :lol: , but i can't figure out yet and find the correct patch, only if there's just better way to get this done :wallbash headache :lol:
