Administrators MaLd0n Posted January 27, 2020 Author Administrators Posted January 27, 2020 Yes sorry too many attempts... config.plist.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
lorenzoyop Posted January 28, 2020 Posted January 28, 2020 config.plist.zip Back to previous state, screen is down after initial bootlog: I have two outputs, one HDMI and one DP, using the HDMI connector as I don't have any DP cable... Should I test if that output is working (need to source a DP->HDMI adapter in that case) ?
Administrators MaLd0n Posted January 28, 2020 Author Administrators Posted January 28, 2020 Back to previous state, screen is down after initial bootlog: I have two outputs, one HDMI and one DP, using the HDMI connector as I don't have any DP cable... Should I test if that output is working (need to source a DP->HDMI adapter in that case) ? what hardware? desktop or notebook? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
lorenzoyop Posted January 28, 2020 Posted January 28, 2020 what hardware? desktop or notebook? That's a NUC-like mini computer, quite powerful by the way (I'm not using Wifi): https://www.alibaba.com/product-detail/EGLOBAL-Stock-product-high-standard-DDR4_60796551959.html
Administrators MaLd0n Posted January 28, 2020 Author Administrators Posted January 28, 2020 That's a NUC-like mini computer my config.plist above don't work? if not, u can change only connectors, is a very personal thing -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Hiko Posted April 19, 2020 Posted April 19, 2020 I can't choose Coffee Lake if I use 'Current Version'. It keeps jumping back to 'Ice Lake(LP)'. I am using i9 9900k, and I set my Hackintosh as iMac 19.1. However, there are several incorrect system info that I can find in Hackintool. Not sure how to fix them.
Administrators MaLd0n Posted April 20, 2020 Author Administrators Posted April 20, 2020 1 hour ago, Hiko said: I can't choose Coffee Lake if I use 'Current Version'. It keeps jumping back to 'Ice Lake(LP)' bugs? report to dev in GitHub -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ricarrdo Posted April 25, 2020 Posted April 25, 2020 I'm trying to patch my video on my notebook, but after reboot, the screen keeps blinking, not sure it there's something missing My processor is intel i5-8256u
Administrators MaLd0n Posted April 25, 2020 Author Administrators Posted April 25, 2020 3 hours ago, ricarrdo said: My processor is intel i5-8256u try my patch from here https://www.olarila.com/topic/6874-olarila-hackbook-lenovo-ideapad-s145-mojave-catalina-full-dsdt-patches-clover-and-opencore/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted April 30, 2020 Author Administrators Posted April 30, 2020 5 hours ago, Kyaalod said: Will this work on opencore? yes -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
osxi7 Posted May 29, 2020 Posted May 29, 2020 How to change video ram? intel i9 9900k UHD 630 I cannot find platform id for mac pro 7.1 ? gpu device id =0x3E988086 1536 MB video ram Quartz Extreme (QE/QC1) Yes Metal Supported = Yes Metal Low Power= Yes Metal Headless =No Video Decoder failed but have transparency and have 4k playback of video how to find platform id how to increase video ram any advice very much appriciated or point to web material
Administrators MaLd0n Posted May 29, 2020 Author Administrators Posted May 29, 2020 2 hours ago, osxi7 said: How to change video ram? cosmetic, ignore it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
rositaott Posted June 7, 2020 Posted June 7, 2020 Hi @MaLd0nI have working graphics both external and on-board display, but when I use them both, only the external graphic card is working, how to enable dual monitor...need your kind help thank you... Screen Shot 2020-06-07 at 1.41.18 PM.zip Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
Administrators MaLd0n Posted June 7, 2020 Author Administrators Posted June 7, 2020 11 hours ago, rositaott said: Hi @MaLd0nI have working graphics both external and on-board display, but when I use them both, only the external graphic card is working, how to enable dual monitor...need your kind help thank you... u need use only dgpu, internal graphics stay only for intel quick sync 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
rositaott Posted June 8, 2020 Posted June 8, 2020 18 hours ago, MaLd0n said: u need use only dgpu, internal graphics stay only for intel quick sync as always...thank you very much...I have dual display now and even triple display 1 Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
NadeejaNirmala Posted August 11, 2020 Posted August 11, 2020 @MaLd0n i have successfully installed macOS catalina on my sandy bridge machine, i just wanna know how to fix intel hd2000, pls can you help me ?https://imgur.com/hDcZjgr
Administrators MaLd0n Posted August 11, 2020 Author Administrators Posted August 11, 2020 6 hours ago, NadeejaNirmala said: how to fix intel hd2000 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
alisha Posted August 18, 2020 Posted August 18, 2020 Hi Maldon, Does this method work on Catalina? cause I have no seen my system version on framebuffer tabs, its only show Local kexts, Mac Os 10.13.6 and Mac OS 10.14 Thanks in advance
Administrators MaLd0n Posted August 18, 2020 Author Administrators Posted August 18, 2020 3 hours ago, alisha said: Hi Maldon, Does this method work on Catalina? yes select 10.14 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
