[Solved] Z170+Skylake Mojave 10.14.3 + Intel 530+Sound
Hello,
Can someone help me create Clover EFI folder for Mojave 10.14.3 please.
My hardware:
=i7-6700k processor
=Intel HD 530 [works fine in High Sierra out of the box connected via VGA to Samsung monitor]
=Sound [Realtek builtin]
=WiFi and LAN [intel WiFi 8260 and Builtin Realtek Ethernet]
=USB and motherboard drivers
=500GB HDD
SMBIOS: iMac 17,1
I have attached my EFI folder in case it needs tweaking. Thank you :)
EFI.zip
your wifi will not work use this clover folder https://Olarila.com/files/Clover.Folder/CLOVER.SERIES.100.200.300.zip
usb here https://Olarila.com/forum/viewtopic.php?f=79&t=7370
you should have a dsdt completed from here https://Olarila.com/forum/viewtopic.php?f=19&t=1131
an you gpu will not work in mojave so best is to be with high sierra
:superman:superman
yes intel 530 is but you have a 1060 an that doesnt work in mojave
:superman:superman
Ahh yeah. That is fine. I am happy with Intel 530 :) I am gonna re-install High Sierra and create Mojave from there. I heard that creating bootable USB etc .. from VMware can cause troubles as well.
By the way, which WiFi and Bluetooth do you recommend for High Sierra which would be compatible in Mojave? :)
you can create a usb in windows also just follow this guide here https://Olarila.com/forum/viewtopic.php?f=50&t=8685
TP-Link Archer T9E will work
:superman:superman
Hi,
I am back :P and managed to get Mojave installer working through Clover latest version kexts and UEFI drivers. I have attached the EFI file.
Problem was that it was booting without ACPI settings and kernel and kext patches. If I booted it up with Nvidai 1060GTX then it would boot without any issues and install, obviously without Nvidia acceleration due to lack of driver . If I boot with Intel 530 it may or may not work and therefore made changes to the EFI file which I attached here.
Now I need to figure out how to make Intel 530 work with full acceleration and my built in Realtek sound.
Need to see what WiFi and Bluetooth cards work out of the box for Mojave.
I thought I would share this with you guys. Thank you :)
Added in 2 minutes 44 seconds:
Re: [solved] Help me with EFI folder please Mojave 10.14.3
If anyone knows how to make Intel 530 work under Mojave, please do let me know. I am looking into patching frame buffer guides as well to see if I can implement something. Thank you :)
EFI_Mojave_Working.zip
just InjectIntel work
I am back again :)
Got Mojave working on my motherboard including Intel 530, Sound, Intel bluetooth.
I have attached the EFI folder. Note that I am using VGA connection to the monitor and who ever downloads this and using HDMI / DP connection to their monitors need to change the value in Clover application> Graphics> ig-platform-id> Choose Intel 530 from the list depending on what Mac you are emulating etc ...
No need for fake ID and you will be booted to Apple logo without any forbidden sign.
Got Internet working as well through Bluetooth. My Galaxy S7 Edge passing on Internet to my machine through Bluetooth.
Thank you :)
Z170chipset_Skylake.zip
[ref]Eternity87[/ref], :guitar:guitar
:superman:superman
Dear @MaLd0n
Please I need your help
I've installed Mojave
I am trying to use platform id : 0x19120000 I get black screen
and id : 0x19120001 cause KP and reboot
I want use IGPU intel HD 530 with Displayport for 4K monitor
Only the one is working id : 0x193b0005 ; and it show in my system as Iris pro 580
I've tried everything imac 17.1 14.2 Mac pro 6.1 ; I am looking for a fix everywhere and no result
I want use real platform id to get correct framebuffer
What I want is possible or impossible to happen?!!
I will upload all needed files upon your reply
Thank you
Asus z170i pro gaming
Intel i7 6700k
32 gb ram
[ref]Zkingtut[/ref], try other output video, if work use hackintool for create a correct video patch
You mean I should try HDMI ?
I did that ; but Hdmi is limited to @30hz ;
And I used Hackintool to create frmaebuffer but once I reboot with DisplayPort and ID 0x19120000 again black screen
I tried with and without Whatevergreen; and IntelFixUp
No way
