Hello, i am new to the topic DSDT and SSDT patching.
I have managed to fix most of the errors of my DSDT and SSDT files for my laptop.
But in two of the SSDT's there are the the same errors over and over when i click compile in MaciASL.
I don't see in the code where the errors could be.
Can somebody help me to fix the errors in my files?
I have attached to this topic all my files. The errors are in SSDT-0... and SSDT-1...
Or at least an explanation for what I can do or what I do wrong.
DSDT SSDT.zip
u dot' need patch ssdts
what ur mobo?
Oh ok, I didn't know that. I thought I have to fix all of the files.
This is a Laptop: Wortmann Terra Mobile 1529H with the motherboard: Clevo W550SU1
This are the complete specs:
15,6" WXGA (1366x768)
Intel Haswell HM86 Chipset, Intel Core i5-4210M, Intel HD Graphics 4600, 8GB Samsung DDR3L 1600MHz Ram,
Samsung 850 EVO SSD mSATA, DVD Drive SATA, Toshiba SATA HDD,
Realtek RTL8111 PCI-E Networkcard, Realtek ALC269 Soundcard,
OS X Mojave + Clover (4868) UEFI Boot
The Problem is that for the sound I have to use VoodooHDA patch because AppleALC doesn't work (I have testet all layout-id's).
When I close the lid, the screen turn off but the laptop is still going (for example music is still playing). And when I open it, the screen doesn't turn on again. I have to force power off and restart the laptop.
HDMI doesn't work at all (a pluged monitor wont even show in display settings).
I can't change the backlight brightness.
All other I think works good. iMessage and Facetime work. Even my frontcamera work. Headphone and Microphone work. Internal and the 3,5mm plugs. The internal speaker work only mono, so I have to slide in the audio option complete to the left speaker. But headphone work both so I guess it is only a problem with the VoodooHDA patch.
The keys for audio volume change work too. But for the brightness they don't.
[ref]alex2244[/ref], DSDT.aml.zip
use it
change EHC1 to EH01
45484331
45483031
change EHC2 to EH02
45484332
45483032
change GFX0 to IGPU
47465830
49475055
change HECI to IMEI
48454349
494d4549
change SAT0 to SATA
53415430
53415441
after reboot send _me full dump
--Run_Me
RunMe.app
Ok I put the DSDT file from you in the Clover patched folder and make sure that is loaded.
I am not sure what to expect.
The System runs like before. When I close the lid music is still playing and the screen doesn't turn on again on open, I have to make a hard reset.
But when I force turn off the laptop and turn it on again it behaves like it is woke up (spotify an other apps are still open).
The "sleep" button on the apple logo in the upper left corner works partly. music stops playing and the screen turn off. after a click with the mouse or keyboard it turns on again (but the rest of the system is running for example the hard drive or the fans.)
Did I have to turn off all other fixes from the clover configurator or deleting kexts or something like that?
Or must I put the SSDT* files in the "patched" folder too?
[ref]alex2244[/ref], extract new SEND_ME
Sorry for my stupid question(s). But do you mean that I should place the DSDT from you in the „patched“ folder and start the „RunME“-App again and place the new .zip here?
[ref]alex2244[/ref], yes
Ok here is the new .zip created with the RunME app with the new DSDT in the patched folder.
Can you help me to understand some terms?
"To inject" means that OS X see a device which it doesn't see out of the box?
For example "inject NVIDIA" means that OS X see a NVIDIA card which are without inject it don't see?
A patched DSDT means that I don't need to set anything in the CloverConfigurator ACPI Section?
To fix a DSDT means that I have to solve all the errors when I click compile in MaciASL?
What exactly do a DSDT "patch"? My knowledge is, that it makes a device to act like on a real mac?
Send me Alexanders-MBP.fritz.box.zip
Prezado amigo temminato184,
Segue a EFI com tudo funcionando.
Eu tenho o mesmo laptop que o seu. Consegui injetar tudo.
Pode usar com o Big Sur tranquilamente.
https://www.mediafire.com/file/zbyz7v94k36d9t8/EFI.zip/file
