Daveman Posted January 26, 2019 Posted January 26, 2019 Hello, I recently built my new Hackintosh. The USB installer I used had 10.14.3 on it. Everything seemed to work flawless, however I noticed I frequently get freezes (mouse does not move) when randomly browsing in Safari. I've had it when scrolling in Google Maps, when going back to a tab that has a Youtube video playing, ...It does not freeze always when I visit those websites, but it does sometimes. When browsing to "simple" - like only text - websites, it never freezes. I have attached 4 textfiles with the log from 4 kernel panics. Can someone please help me out? When the freezes occur, I have internet connection via built in Ethernet (Intel® GbE LAN chips (10/100/1000 Mbit) -> Intelmausiethernet kext) My system: Os: 10.14.3 Motherboard: Gigabyte H170N WIFI CPU: Intel i7 6700 skylake GPU: Gigabyte RX 580 8gb Replaced the built in wifi card with Aliexpress "dell DW1560 BCM94352Z" Thank you, kernal panic.rtf kernel panic 2.rtf kernel panic 3.rtf kernel panic 4.rtf
Administrators MaLd0n Posted January 26, 2019 Administrators Posted January 26, 2019 [ref]Daveman[/ref], post ur files --Run_Me RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Daveman Posted January 26, 2019 Author Posted January 26, 2019 I have attached the files. Send me Hackintosh.zip
Administrators MaLd0n Posted January 26, 2019 Administrators Posted January 26, 2019 [ref]Daveman[/ref], CLOVER.zip use only it, reboot and extract new SEND_ME -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Administrators MaLd0n Posted January 26, 2019 Administrators Posted January 26, 2019 [ref]Daveman[/ref], looks good u test? u need it too --USB Fix https://Olarila.com/forum/viewtopic.php?p=65287#p65287 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Daveman Posted January 26, 2019 Author Posted January 26, 2019 If been trying different websites but it does not freeze. It seems that it is okay. What was the reason for the freeze? I will now try to do the USB fix you mentioned. Thank you very much.
Administrators MaLd0n Posted January 26, 2019 Administrators Posted January 26, 2019 [ref]Daveman[/ref], -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
sw_henrique Posted January 29, 2020 Posted January 29, 2020 Poxa mald0n voce é maravilho ! Estou tendo o mesmo problema e vou tentar corrigir com suas dicas
sw_henrique Posted January 29, 2020 Posted January 29, 2020 Esse problema de congelar a tela e o mouse nao tem nada aver com a GPU ?
Administrators MaLd0n Posted January 29, 2020 Administrators Posted January 29, 2020 Poxa mald0n voce é maravilho ! Estou tendo o mesmo problema e vou tentar corrigir com suas dicas depende tem de usar um dsdt full patched pra deixar nosso hack igual a um mac o nosso bios/uefi não foi feito pra macos -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
sw_henrique Posted January 29, 2020 Posted January 29, 2020 Muito obrigado pela atencao ! Eu acabei por solucionar com a pasta clover que enviou acima. Cheguei a pensar que era algo no perfil da memoria ou o usb, pois nao estava achando o erro. Ja estou a mais de 8 horas utilizando e tudo normal !!! Novamente muito obrigado. Assim que eu puder vou fazer uma doação pois é muito importante valorizar esta comunidade !
