ph33rz Posted January 24, 2019 Posted January 24, 2019 (edited) Okay so I have literally tried everything I have found online to get this card to work. Can one of you guys please give me a hand. I have tried every method I could find new and old from adding kext to modifying the GFX to IGFX and can't figure this out. I have the "Nvidia GTX 1080" Its not a evga or any of that its actual Nvidia and its not a ti its just gtx. Send me iMac.zip ph33rz-EFI.zip ph33rz-imac.ioreg.zip Edited January 26, 2019 by Guest
Administrators MaLd0n Posted January 24, 2019 Administrators Posted January 24, 2019 [ref]ph33rz[/ref], run it and wait https://Olarila.com/files/Utils/nvidia-update.command.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
ph33rz Posted January 24, 2019 Author Posted January 24, 2019 I have done that several times already. :-\. I will try again tho. Added in 1 minute 7 seconds: Downloading driver blacklist... % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 140 100 140 0 0 734 0 --:--:-- --:--:-- --:--:-- 736 Downloading driver list... % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 64859 100 64859 0 0 29100 0 0:00:02 0:00:02 --:--:-- 29110 Could not find a release for your OS. The latest recommended release is: 387.10.10.10.40.113 which is already installed. logout Saving session... ...copying shared history... ...saving history...truncating history files... ...completed. [Process completed]
Administrators MaLd0n Posted January 24, 2019 Administrators Posted January 24, 2019 NvidiaWeb is Checked here? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
ph33rz Posted January 24, 2019 Author Posted January 24, 2019 I have tried that method aswell. If I was to reinstall high Sierra would I need to get another DSDT file from you or can I use the one I have. Also if I do reinstall do I need to update high Sierra to the latest version before applying the DSDT and Nvidia web ?
erroruser Posted January 24, 2019 Posted January 24, 2019 there should be no issues installing in high sierra as its the only stable os for web drivers AMD Ryzen 7 3700X, MSI MPG X570 Gaming Plus, Corsair Vengeance RGB PRO 16GB DDR4 3200MHz, Sapphire rx 5700 XT, fractal celcius s36 HP Notebook - 15-ay028ca (Touch), 16 GB 2133 MHz DDR4, Intel HD Graphics 520 1536 MB Asus z97-c i5, i5 4460, 32 GB 1648 MHz DDR3, Radeon RX 560 4096 MB, Corsair H75 Liquid CPU Cooler
Administrators MaLd0n Posted January 24, 2019 Administrators Posted January 24, 2019 [ref]ph33rz[/ref], if nothing work, ur problem is nvram, nvidia driver need it, use emuvariable driver -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
ph33rz Posted January 24, 2019 Author Posted January 24, 2019 alright I'll double check those things now and report back thanks guys ! Added in 3 minutes 55 seconds: Do I need to leave the Nvidiastartupweb patch in my kernel and kext patches? Also do I need to leave the GFX to IGPU patch in my ACPI?
Administrators MaLd0n Posted January 25, 2019 Administrators Posted January 25, 2019 [ref]ph33rz[/ref], use my clover folder for chipset x99, check Olarila.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
ph33rz Posted January 25, 2019 Author Posted January 25, 2019 I did for the most part my machine wasn't booting when I tried to use it without applying anything else to it. I do need to do the smbios part of the configuration on it correct?
Administrators MaLd0n Posted January 25, 2019 Administrators Posted January 25, 2019 clover set one for u -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
ph33rz Posted January 25, 2019 Author Posted January 25, 2019 Added in 14 minutes 9 seconds: alright so when i started it back up the display cut off right as the desktop would of loaded i have the monitor connected through HDMI is there anything i was suppose to do to make sure it used that? Added in 6 minutes 26 seconds: I was able to get the machine to boot by goin into the options on the clover enabling the HDMI fix when it booted up however it still wasn't using the Nvidia display. Gonna check into if I have nvram enabled or not and how to enable it.
ph33rz Posted January 25, 2019 Author Posted January 25, 2019 performed the checks nvram is showing that it is working. Nvidia is still how ever not.
ph33rz Posted January 25, 2019 Author Posted January 25, 2019 I’m starting to lose hope I been at this for 2 weeks now with 3 different sites trying to figure it out idk what I’m doing wrong. Hopefully it’s something dumb I am overlooking
Administrators MaLd0n Posted January 25, 2019 Administrators Posted January 25, 2019 [ref]ph33rz[/ref], extract new SEND_ME -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
ph33rz Posted January 26, 2019 Author Posted January 26, 2019 Sorry it took so long I had to work today. Here you go! Thank you again! If you think I should just completely reinstall and start over just let me know. I tried everything last night. I tried just booting with only the Nvidia web option checked and every other variant I could try from boot flags to trying to inject Nvidia etc. Had no luck at all but when I initially enabled the option by its self my pc booted up but I had no display. It was on during the initial boot up but turned off when desktop loaded. My tv is what I use as a display its a LG ultra 4k tv using HDMI Do I need to shave sip enabled? Added in 11 minutes 13 seconds: run me zipSend me Mac-Pro.zip Added in 5 minutes 40 seconds: I tired before and after updating Mac OS also. io jones send me.zip
Administrators MaLd0n Posted January 26, 2019 Administrators Posted January 26, 2019 [ref]ph33rz[/ref], use a fresh install CLOVER.zip after install run it for video https://Olarila.com/files/Utils/nvidia-update.command.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
ph33rz Posted January 26, 2019 Author Posted January 26, 2019 Your the man that did work! Am I able to do updates? Am I able to choose the 4k resolution without breaking anything also?
Administrators MaLd0n Posted January 26, 2019 Administrators Posted January 26, 2019 [ref]ph33rz[/ref], 4k only via DP, ye, update extract new SEND_ME -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
ph33rz Posted January 27, 2019 Author Posted January 27, 2019 here you go. I am running resolution at 3840x2160@30hz whenever i try to run at 60hz with the same resolution my tv acts like it cant support it. But it does. Added in 6 minutes 35 seconds: also i dont think osx is using all the ram my pc has? Also is the hyper threading cores enabled? Added in 39 seconds: also if we reserved 2gb of my ssd for swap memory would that increase system performance? Added in 3 minutes 13 seconds: crap and i was also wondering too about bluetooth ? My board has it built in but wasnt sure if osx was seeing it or not didnt see any options for it. Send me ph33rzs-iMac.zip
Administrators MaLd0n Posted January 27, 2019 Administrators Posted January 27, 2019 [ref]ph33rz[/ref], MORE PATCHES DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
d4ct Posted January 27, 2019 Posted January 27, 2019 Same boat. It looks like we're working on, essentially, the same machine. About to give it another go... Wish me luck. - d4ct (Sony Music / Sonido Local Recordings / Ultra)
ph33rz Posted January 27, 2019 Author Posted January 27, 2019 maldon was i suppose to replace the current dsdt with that one becaus thats what i did and graphics stopped working I was able to get them back working by reinstalling the driver. I also just noticed that my CPU is running extremely hot. Sitting at around 95c which isnt good at all this machine usually runs at 50-60c what can I do. I went and turned off all over clocks and enabled speedsteps.
Administrators MaLd0n Posted January 27, 2019 Administrators Posted January 27, 2019 [ref]ph33rz[/ref], u need some patch to kernel in x99, processors don't have a native support https://www.insanelymac.com/forum/topic/335650-kernelandkextpatches-1013x1014x-x99/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
