[ref]rositaott[/ref], u have a patch in _q11 and _q12
Scope (_SB.PCI0.LPCB.EC0)
       Method (_Q11, 0, NotSerialized)  // _Qxx: EC Query, xx=0x00-0xFF
           Notify (KBC0, 0x0205)
           Notify (KBC0, 0x0285)
       Method (_Q12, 0, NotSerialized)  // _Qxx: EC Query, xx=0x00-0xFF
           Notify (KBC0, 0x0206)
           Notify (KBC0, 0x0286)
Hi MaLd0n, yes but I have 2 sets of brightness controls one is the correct keys (Fn+left arrow & Fn+right arrow) the other keys are (Fn+F12 & Fn+Pause/Break keys), I want to remove the brightness control from these keys (Fn+F12 & Fn+Pause/Break keys)
Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
[ref]rositaott[/ref], what is the EC method for Fn+F12 & Fn+Pause/Break keys? Assuming they are _Q47 and _Q45, you could possibly try disabling by renaming them. Not too sure if it'll work though. But its worth a shot.
Donate
Gitter Chat
MSI B360 Gaming Arctic
[ref]rositaott[/ref], what is the EC method for Fn+F12 & Fn+Pause/Break keys? Are they _Q47 and _Q45? You could possibly try disabling by renaming them. Not too sure if it'll work though. But its worth a shot.
I think so, but how to rename it?
how to rename it?
XQ47/ XQ45 should suffice
Donate
Gitter Chat
[ref]rositaott[/ref], Well, you did say you are unsure of the EC method for Fn+F12 & Fn+Pause/Break keys. :meeting
Donate
Gitter Chat
I did, that maybe the reason why I wasn't able to :lol:
[ref]rositaott[/ref], use debug and check what u need remove
same keys are showing even I only press Fn+F12,Fn+Pause/Break
always show EC Q45, Q47, Q11 Q12
[ref]dinimuhtar[/ref], this tutorial is for all system
i hava a brighness keyboard in aura syn in my laptop asus fx505ge i5, then how remapping britghtness my keyboard?
READ FIRST POST
Donate
Gitter Chat
into method label _Q1D replace_content
begin
// Brightness Down\n
Notify(\_SB.PCI0.LPCB.PS2M, 0x0205)\n
Notify(\_SB.PCI0.LPCB.PS2M, 0x0285)\n
end;
into method label _Q1C replace_content
begin
// Brightness Up\n
Notify(\_SB.PCI0.LPCB.PS2M, 0x0206)\n
Notify(\_SB.PCI0.LPCB.PS2M, 0x0286)\n
end;
I've done my device is PS2K when is paste patch then apply option no highlighted but my brightness hotkeys doesn't work
What is your EC method?
Donate
Gitter Chat
ec0 to ec rename
Wrong answer. Read the guide again.
Donate
Gitter Chat
