[ref]mut0u[/ref], One more error to fix
kernel: (AppleACPIPlatform) ACPI Warning: \_SB.PCI0.I2C0.TPD0._DSM:
Donate
Gitter Chat
MSI B360 Gaming Arctic
[ref]mut0u[/ref], You might want to try interrupt mode for your trackpad.
Just change SBFI to SBFG at TPD0._CRS method. Follow the pic below.
https://imgur.com/f4NPYt8
Donate
Gitter Chat
@onemanosx
OK added
but Boot up for a long time
once again Thank you
new sendme file
Error logs are gone. For that long boot time, maybe you can try to clear NVRAM and see if it helps. If the long boot time bothers you, then just change back to SBFI.
I don't see any other major issues. Just enjoy your hack. :smoke:
Donate
Gitter Chat
The touchpad is not working
Change back to SBFI.
Donate
Gitter Chat
@onemanosx
When I upgrade VoodooPS2Controller.kext (2.0.3)
Problem Details and System Configuration
Backtrace (CPU 4), Frame : Return Address
0xffffff82e4a03980 : 0xffffff80193ad6ed
0xffffff82e4a039d0 : 0xffffff80194e9185
0xffffff82e4a03a10 : 0xffffff80194da8ba
0xffffff82e4a03a80 : 0xffffff801935ab40
0xffffff82e4a03aa0 : 0xffffff80193ad107
0xffffff82e4a03bc0 : 0xffffff80193acf53
0xffffff82e4a03c30 : 0xffffff80194daadd
0xffffff82e4a03da0 : 0xffffff801935ab40
0xffffff82e4a03dc0 : 0xffffff7f9cc68977
0xffffff82e4a03eb0 : 0xffffff8019a2b15a
0xffffff82e4a03f00 : 0xffffff8019a2df3b
0xffffff82e4a03f50 : 0xffffff8019a2fae6
0xffffff82e4a03fa0 : 0xffffff801935a0ce
Kernel Extensions in backtrace:
as.acidanthera.voodoo.driver.PS2Controller(2.0.3)[CB316A67-7868-3E0D-8D70-1204C92A6564]@0xffffff7f9cc66000->0xffffff7f9cc75fff
dependency: com.apple.iokit.IOACPIFamily(1.4)[3E8E9870-2E41-33F6-ACBF-35DDC08F22B5]@0xffffff7f9a28a000
BSD process name corresponding to current thread: kernel_task
Boot args: brcmfx-driver=1 brcmfx-country=#a
Any suggestions?
@onemanosx
Any suggestions?
From what I gather the panic will disappear if trackpad is running in interrupt mode.
Donate
Gitter Chat
have a 2.0.4 version, check if fix this problem
@MaLd0n
0xffffff82d722b980 : 0xffffff800b3ad6ed
0xffffff82d722b9d0 : 0xffffff800b4e9185
0xffffff82d722ba10 : 0xffffff800b4da8ba
0xffffff82d722ba80 : 0xffffff800b35ab40
0xffffff82d722baa0 : 0xffffff800b3ad107
0xffffff82d722bbc0 : 0xffffff800b3acf53
0xffffff82d722bc30 : 0xffffff800b4daadd
0xffffff82d722bda0 : 0xffffff800b35ab40
0xffffff82d722bdc0 : 0xffffff7f8ec68977
0xffffff82d722beb0 : 0xffffff800ba2b15a
0xffffff82d722bf00 : 0xffffff800ba2df3b
0xffffff82d722bf50 : 0xffffff800ba2fae6
0xffffff82d722bfa0 : 0xffffff800b35a0ce
as.acidanthera.voodoo.driver.PS2Controller(2.0.4)[E2927F57-AEFE-372E-ACAD-19C77D1D69E9]@0xffffff7f8ec66000->0xffffff7f8ec75fff
dependency: com.apple.iokit.IOACPIFamily(1.4)[3E8E9870-2E41-33F6-ACBF-35DDC08F22B5]@0xffffff7f8c28a000
I can only use USB disk boot up
Added in 9 minutes 56 seconds:
I using VoodooPS2Controller.kext (1.9.2)
Added in 4 minutes 41 seconds:
@onemanosx
Where should I post the sleep wakeup restart?
What information is needed?
[ref]aryaone[/ref], use dsdt from acpi/patched. Remember to make a backup of the working DSDT
[ref]onemanosx[/ref], thanks for your tutorial, i already success remapping my brightness hotkey. but i notice that the old hot keys is still work, do you now how to disable the old hotkey?
@aryaone
How to remapping my brightness hotkey
prior to is Fn + F11 down / F12 up
just now is Fn + s down / b up
You can help me ,Is there a tutorial?
Thank you
if you can find the ec method for the old hotkeys, it is possible to disable it in DSDT, I suppose.
Added in 43 minutes 27 seconds:
Open a new topic. Let's try not to clutter this topic with unrelated issues.
Donate
Gitter Chat
I have the same issue, how to disable EC method for old hotkeys....thank you. :cap
Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
Like I had mentioned, it is possible to find the EC method of the old hotkeys using debug method then disable it via DSDT. Is this a DELL laptop, too?
Donate
Gitter Chat
ACER Laptop...I don't know how to disable it via DSDT if I'll be able to find the EC method :)
Find the EC method then upload your working DSDT
Donate
Gitter Chat
<IMGUR id="42ybCnj"><a href=https://i.imgur.com/42ybCnj.png' alt='IMGUR>'>
and my DSDT
Added in 1 minute 31 seconds:
[ref]onemanosx[/ref], By the way I'm curios, how to disable via DSDT, can you also share how to do it, thanks a lot! :)
