can you help me im trying to fix my battery status but always got error
am i doing it wrong?
into device label H_EC code_regex B1RA,\s+16, replace_matched begin BRA0,8,BRA1,8, end;
into device label H_EC code_regex B1DF,\s+16, replace_matched begin BDF0,8,B1DF,8, end;
into device label H_EC code_regex B1PR,\s+16, replace_matched begin BPR0,8,BPR1,8, end;
into device label H_EC code_regex B1VO,\s+16, replace_matched begin BVO0,8,BVO1,8, end;
into device label H_EC code_regex B1DA,\s+16, replace_matched begin BDA0,8,BDA1,8, end;
into device label H_EC code_regex B1DV,\s+16, replace_matched begin BDV0,8,BDV1,8, end;
into device label H_EC code_regex B1DL,\s+16, replace_matched begin BDL0,8,BDL1,8, end;
into device label H_EC code_regex CYLC,\s+16, replace_matched begin CYL0,8,CYL1,8, end;
[ref]rogeriovasco[/ref], You got the first part of patching correct.
Now its time to correct these errors:
https://imgur.com/wxWxlzl
e.g for B1DA -> B1B2(\_SB.PCI0.LPCB.H_EC.BDA0,\_SB.PCI0.LPCB.H_EC.BDA1)
1. Find B1DA in DSDT
2. Paste
over "B1DA" like so
https://imgur.com/0irIotW
Do the same for all the remaining 9 errors.
And lastly introduce the B1B2 and EC essential patches.
Donate
Gitter Chat
MSI B360 Gaming Arctic
2. Paste
over "B1DA" like so
thank you now i can see the battery icon i appreciate your help
the problem now is battery status show at top bar but it not update status it stay 37% the whole time. When I connect or disconect charge the sistem stop work it freezes
[ref]rogeriovasco[/ref], Looks like you missed out BTPC, 16, integer to fix.
Always a good practice to double check our works.
Donate
Gitter Chat
yeah sure, finelly got it to work thank you for your help
[ref]rogeriovasco[/ref], :cap:guitar
Donate
Gitter Chat
My battery status shows percent just fine after I install(without doing nothing) but when I plug/unplug charger. It freeze. So I try to patch the battery and I see this screen. What should I do? Thanks in advance!
What should I do?
Maybe, read and follow the guide?
Donate
Gitter Chat
[ref]minhphan244[/ref], what happens if you install battery kext?
Donate
Gitter Chat
It works (show exactly percentage, warning low battery) but battery indicator not recognize when i plug/unplug AC adapter and percentage battery still increase, system report still recognize charging, i don't know how to solve it @@
[ref]minhphan244[/ref], No idea. Never faced a DSDT like yours before.
Donate
Gitter Chat
[ref]hawkins1986[/ref], no idea without your DSDT file and/or description of what you attempted to get that error.
Donate
Gitter Chat
I can't upload .dsl file.
Scroll down and look for the add files icon. Or, upload somewhere in your prefered cloud e.g google drive
https://imgur.com/JAIGQwb
Donate
Gitter Chat
