I don't know what is second part of the patch
its in the link you provided by the OP
Donate
Gitter Chat
MSI B360 Gaming Arctic
I really dont know what you mean. I just changed the string "Ones" by "7200" in "Name (BPKG, Package (0x0D)" function as in that provided link and I can see the battery status, although not very exact.
Looks to me, that is not the only change made by the OP. See screenshot
https://imgur.com/a/xHpxwsW
Donate
Gitter Chat
[ref]Wizzard[/ref], for sake of troubleshooting, try this and report back.
Donate
Gitter Chat
It works, but still it shows the percentage higher than in Linux (approx. 95 percent against 90 percent) so maybe it still needs another tweaking.
Does percentage decrease or increase with use?
Donate
Gitter Chat
Decrease, of course :) The percentage is always 3-5 percent higher than in Linux.
The difference between OS is commendable, I think. You may try and input your custom _BIF as per the documentation (https://github.com/gsly/OS-X-ACPI-Battery-Driver/wiki/_BIF-Method), if you are up for it.
Anyway, appreciate if you can test this DSDT and see if battery status works. Thanks in advance.
Added in 6 minutes 38 seconds:
instructions on whether I can convert the DSDT itself for operation SSDT-BAT please, please give me the whole information
whole information here https://github.com/RehabMan/OS-X-ACPI-Battery-Driver
Donate
Gitter Chat
Yes, works, but still showing percentage a few percent higher than Linux/Windows.
Thank you for testing. This DSDT proves that battery capacity patch is not required. Appreciate your feedback.
I wont worry abt the few % off linux/windows.
Donate
Gitter Chat
