fabioad Posted October 6, 2020 Posted October 6, 2020 Model: Avell High Performance 1513 (0% Battery problem)DSDT: https://drive.google.com/file/d/1WoC_OYdprHjGhOhT1jXwtxEEx_JfwQMI/view?usp=sharingReport.html: https://drive.google.com/file/d/1afGEvyCHEstxlAEK6D6EYTBHPFi7FP-8/view?usp=sharing DSDT + Report.zip
Administrators MaLd0n Posted October 6, 2020 Administrators Posted October 6, 2020 40 minutes ago, fabioad said: Model: Avell High Performance 1513 (0% Battery problem) DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ndeni Posted October 14, 2020 Posted October 14, 2020 (edited) Greetings, my problem is the following: before I had my build in high sierra with clover and it used the rehabmab battery_WBIN-Airbook patch that was compatible with my battery and it worked fine but now I did a new installation with opencore catalina, I apply the same patch to the ssdt and the battery status no longer shows, I also patched my dsdt following the rehab guide and nothing. Somebody could help me? my laptop is a compaq presaria 21-N2F5AR. I used virtualmsc and fakemsc with their respective kexts for drums and neither of them worked. My zip with EFI folder. https://drive.google.com/file/d/10iCfAWQn192CXBQAEhGBhB0AsX5c_X1B/view?usp=sharing Edited October 15, 2020 by ndeni
Administrators MaLd0n Posted October 14, 2020 Administrators Posted October 14, 2020 use virtualsmc with battery plugin instead -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ndeni Posted October 15, 2020 Posted October 15, 2020 (edited) 4 hours ago, MaLd0n said: use virtualsmc with battery plugin instead Hi MaLd0n, yes, I tried both. With virtualSMC with battery plugin and with fakeSMC but neither of them worked for me. From what I see I have a machine similar to R-88 that I wrote above because the patch that works with my battery is the same one that he uses. But it doesn't work anyway. Could you take a look at my DSDT and see if there is something wrong? I would greatly appreciate it. As I value your work, I can donate you some Bitcoin if you solve it for me. thank you very much! Edited October 15, 2020 by ndeni
fabioad Posted October 16, 2020 Posted October 16, 2020 On 10/5/2020 at 11:30 PM, MaLd0n said: DSDT.aml.zip 33.36 kB · 1 download This ACPI error occurs with your DSDT
Gustavo1610 Posted October 26, 2020 Posted October 26, 2020 On 1/1/2019 at 2:02 AM, onemanosx said: Actualización 3 de enero de 2019 Excellent tutorial, in my case I have a DSDT created by Mald0n a long time ago, but I have the problem that the battery of 100% that is shown in the bar, does not decrease, staying frozen with that percentage, some solution please.
stalvatero Posted November 11, 2020 Posted November 11, 2020 Hi guys, I have a perfect Catalina installation on my HP Laptop (check sign) thanks to a patched DSDT by @MaLd0n. Using OpenCore, all is working great (PM, Sleep/Wake, USB, QI/QE, WiFi and Bt). Also battery seems to work as it should do...but I only use VirtualSMC and battery plugin. Checking my DSDT I found some integer larger than 8 bit... and moreover I have either H_EC and EC, and I don't know which to watch. Using SSDTTime, a message alert me that only EC is used... but is it true? Right now icon and percentage are working fine, charge and discharge, residual charge,... all is working as expected on a real MacBook. I'm confused... I don't if should be useful trying to patch this few integer I found, or I can leave them in place (and live in peace..) This is my DSDT... Please can someone help me? DSDT.aml.zip
Administrators MaLd0n Posted November 12, 2020 Administrators Posted November 12, 2020 11 hours ago, stalvatero said: Hi guys hey in ur case is ec0 and i think u used ec0 to ec acpi patch rename device EC is there ignore H_EC device in this case -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
stalvatero Posted November 12, 2020 Posted November 12, 2020 5 hours ago, MaLd0n said: in ur case is ec0 and i think u used ec0 to ec acpi patch rename Well no, I haven't any ACPI rename patch. Battery seems to works OOB with only VoodooSCM and battery plugin. Anyway, in DSDT EC, under EmbeddedController I have these part of code: OperationRegion (ERAM, EmbeddedControl, Zero, 0xFF) Field (ERAM, ByteAcc, Lock, Preserve) { Offset (0x5A), Offset (0x5B), Offset (0x5C), Offset (0x5D), ENIB, 16, ENDD, 8, SMPR, 8, SMST, 8, SMAD, 8, SMCM, 8, SMD0, 256, BCNT, 8, SMAA, 24, SMBN, 8, Offset (0x8A) } but only SMD0 is called up down EC region, and OperationRegion (ECRM, EmbeddedControl, Zero, 0xFF) Field (ECRM, ByteAcc, Lock, Preserve) { Offset (0x5D), ERIB, 16, ERBD, 8, Offset (0xAA), Offset (0xAB), Offset (0xAD), , 4, Offset (0xAE), PTVL, 4, Offset (0xB0), Offset (0xB1), Offset (0xB2), Offset (0xB3), Offset (0xB4), Offset (0xB5), Offset (0xBC), Offset (0xBD) } but only ERIB is called up down EC region. So, as far as I understood by this tutorial, I should patch SMD0 find in: So, first... Remane that SMD0... into device label EC code_regex (SMD0,)\s+(256) replace_matched begin SMDX,%2,//%1%2 end; But trying to compile, I receive no errors. So it means that nothing is accessing to this SMD0, so no need to patch it, right? Or I'm not receiving errors because SMD0 is also present in H_EC?? So I leave SMD0 in place without renaming it. Now go to ERIB integer. Following the tutorial in OP, it's ok to rename ERIB into device label EC code_regex ERIB,\s+16, replace_matched begin RIB0,8,RIB1,8, end; but I don't know how to continue because I only have ERIB = Arg0 in two methods right below the Operation region. The tutorials do not cover this case, so Idk what to do. Any help?
Administrators MaLd0n Posted November 12, 2020 Administrators Posted November 12, 2020 if work with virtual smc stay with native things virtualsmc emulate it, is not like acpibatterymanager 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
cedroxim Posted November 13, 2020 Posted November 13, 2020 I have that problem, I have read our friend's @onemanosx guide and also with rehabman's guide to patch the battery, using the DSDT that my friend Damn patched, but I'm confused with something, many things in the guide I don't appreciate in my dsdt. hi @MaLd0n you patched my dsdt but left me a hotpach of the EC, that does not create a conflict when trying to patch the battery at the dsdt level? and there is no way to remove that hotpach. With the rehabman guide I did everything, but with the virtualsmc the indicator works but there comes a time that the kernel_task process goes through the roof, which using the fakesmc does not happen, but the indicator stays frozen when I disconnect or connect the charger, He updates the indicator when I put the laptop to sleep. I migrated from catalina to bigsur, I also migrated from clover to opencore, I have learned a lot in this forum, I only have the problem of the loader, if they guide me to patch it we can create a thread to have the advance. Build CPU: AMD Ryzen 5 3600 MOTHERBOARD: ASUS TUF GAMING X570-PLUS RAM: CORSAIR VENGEANCE RGB PRO 16 GB 2X8 3200 MHZ VIDEO: XFX RX 580 4 GB AUDIO: Realtek ALC1200A
Administrators MaLd0n Posted November 14, 2020 Administrators Posted November 14, 2020 4 hours ago, cedroxim said: I have that problem use ssdts or dsdt dsdt is full solution ssdt is not full but some people using it and stay happy -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
rajuchacharuk Posted December 16, 2020 Posted December 16, 2020 (edited) Offset (0x12), FUSL, 8, 0x12 FUSH, 8, 0x13 FWBT, 64, `0x14` Offset (0x5D), EXSI, 8, 0x5D EXSB, 8, 0x5E EXND, 8, 0x5F SMPR, 8, 0x60 SMST, 8, 0x61 SMAD, 8, 0x62 SMCM, 8, 0x63 SMDA, 256, `0x64` BCNT, 8, SMAA, 8, SAD0, 8, SAD1, 8, Offset (0x8F), BMN0, 72, 0x8F BDN0, 64, 0x98 have I calculated it right? how do I calculate the last one? edit: calculated the last one correct? DSDT.aml Edited December 16, 2020 by rajuchacharuk
osxfr33k Posted April 11, 2021 Posted April 11, 2021 (edited) @onemanosx I agree with you about the offset except it doesn't work that way according to this example Rehabman told me I was wrong. My DSDT example Field (ECF2, ByteAcc, Lock, Preserve) { Offset (0x10), BDN0, 56, //0x10 Offset (0x18), BME0, 8, //0x18 Offset (0x20), BMNC, 8, //0x20 BMN0, 120, //0x21 BCT0, 128, //0x2F <<<< If I go by your way of calculating this should be 0x30 Offset (0x70), BCCL, 8, IDGS, 16, Offset (0x7E), The example you used on the first post looks like this is the way to calculate it. But from what I see you use 0x20 converted to (32) in decimal each time plus only the previous field bits divided by 8. Maybe it was pure coincidence it happed to work out that way in your example but it certainly does not work with my example above, unless Rehabman just happen to have a brain fart that day he replied to me? Rehabman's reply to me: Quote from Rehabman: Wrong. BCT0 is at offset 0x2f (0x20 + (120/8)). Edited: Rehabman must be wrong because if what he is saying is true in my DSDT example then the offset for BCT0 in his example would not be 0x30 but 0x2B. He must have replied to me in error what do you think? Edited April 11, 2021 by osxfr33k OP-LP3 OverPowered Laptop 17 inch, i7-8750H, 32GB memory, 256GB NvMe stock with windows 10 and added 512GB NvMe Samsung 970 Pro with MacOS 11.2.1, OpenCore 0.6.7. New Asus Pro WS X299 Sage II intel i9-10980XE 18 core beast Big Sur 11.2.1. OpenCore 0.6.7, Asus Z390-E i9-9900K 64GB G.Skill Ripjaws Sapphire Pulse RX580, Asus Sabertooth X79 (4) E5-2697 v2 (12 Core), Asus Maximus VIII Hero Alpha i7-7700K 64GB Corsair 2400, Asus Z97-Deluxe i7-4790K, Gigabyte Z77X-UP5-TH i7-3770k, Asus Maximux Formula Special Editions with Rampage Formula Bios conversion, Gigabyte GA-EP35-DS4, GA-EP45-UD3P, GA-G41M-ES2L, GA-Z68X-UD4-B3 and Quo MB. MAC PRO EARLY 2008, MacPro Late 2012. Asus Notebooks: G51JX i7-720QM, G74SX-XT1 i7-2630QM, Asus G750JX-DB71 Haswell Processor i7-4700HQ GTX 770M 3GB (4). Dell Laptops D820, D830, XPS M1530 (6), Dell 13-1567 (4), Older processors i7 (3770K/4770k/6700k/7700K). Older GFX Cards: EVGA GT-640, EVGA GTX 760, EVGA GTX 770 (six),
Guest Posted April 19, 2021 Posted April 19, 2021 Hi guys i did a patch for my battery. Its working but when i wake from sleep my laptop battery is %1. I dont know why. Here my DSDT.dsl DSDT-BATTERY.dsl
StephSkyy Posted April 25, 2021 Posted April 25, 2021 (edited) hello all, Do I need to patch SMD0, 256, ? The next "Find" give me this. Is it accessed? If ((Arg0 == 0x0A)) { SMD0 = Arg3 } If I need to patch it the how do I proceed? The is no Offset to start with: OperationRegion (ERAM, EmbeddedControl, Zero, 0xFF) Field (ERAM, ByteAcc, NoLock, Preserve) { SMPR, 8, SMST, 8, SMAD, 8, SMCM, 8, SMD0, 256, BCNT, 8, SMAA, 8, Offset (0x40), SW2S, 1, , 2, ACCC, 1, TRPM, 1, Thank you for your answers. System DSDT.aml Edited April 25, 2021 by Stephan Malepa
