Dave1482 Posted July 14, 2020 Posted July 14, 2020 (edited) I think I need my DSDT updated again lol, I have an HP Envy 17-u163cl, macOS 10.15.5. The zip was too big than the allowed size, so here is the google drive link. Thank you! https://drive.google.com/file/d/1K1Qvxd03FrUIvIbpEbRtsBlWzx_yCvkG/view?usp=sharing EDIT: Everything pretty much works except for HDMI (it also panics when removing/reinserting an HDMI cable), the SD Card reader, and the battery indicator. Brightness key mapping are not a big priority because I can edit that in Settings. Not sure about the USB-C port either. Edited July 14, 2020 by Dave1482
Killuminati91 Posted July 18, 2020 Posted July 18, 2020 (edited) Hey guys, I cant figure this out for my Matebook X Pro 2020. Followed the guide, but RefOf in my DSDT doesnt seem to be compatible with B1B2. What can I do? into device label HWEC code_regex B0VL,\s+16 replace_matched begin VL00,8,VL01,8 end; into device label HWEC code_regex B0RC,\s+16 replace_matched begin RC00,8,RC01,8 end; into device label HWEC code_regex B0ST,\s+16 replace_matched begin ST00,8,ST01,8 end; into device label HWEC code_regex B0CC,\s+16 replace_matched begin CC00,8,CC01,8 end; into device label HWEC code_regex B0FC,\s+16 replace_matched begin FC00,8,FC01,8 end; into device label HWEC code_regex B0DC,\s+16 replace_matched begin DC00,8,DC01,8 end; into device label HWEC code_regex B0DV,\s+16 replace_matched begin DV00,8,DV01,8 end; into device label HWEC code_regex B0CT,\s+16 replace_matched begin CT00,8,CT01,8 end; into device label HWEC code_regex B0SN,\s+16 replace_matched begin SN00,8,SN01,8 end; into device label HWEC code_regex EKVA,\s+16 replace_matched begin KVA0,8,KVA1,8 end; into device label HWEC code_regex EULV,\s+16 replace_matched begin ULV0,8,ULV1,8 end; into device label HWEC code_regex ELLV,\s+16 replace_matched begin LLV0,8,LLV1,8 end; into device label HWEC code_regex CALS,\s+16 replace_matched begin ALS0,8,ALS1,8 end; into device label HWEC code_regex ELUX,\s+16 replace_matched begin LUX0,8,LUX1,8 end; B0VL -> B1B2(VL00,VL01) B0RC -> B1B2(RC00,RC01) B0ST -> B1B2(ST00,ST01) B0CC -> B1B2(CC00,CC01) B0FC -> B1B2(FC00,FC01) B0DC -> B1B2(DC00,DC01) B0DV -> B1B2(DV00,DV01) B0CT -> B1B2(CT00,CT01) B0SN -> B1B2(SN00,SN01) EKVA -> B1B2(KVA0,KVA1) EULV -> B1B2(ULV0,ULV1) ELLV -> B1B2(LLV0,LLV1) CALS -> B1B2(ALS0,ALS1) ELUX -> B1B2(LUX0,LUX1) Error for each reference: 50994, 6126, syntax error, unexpected PARSEOP_CLOSE_PAREN, expecting PARSEOP_EXP_INDEX_LEFT DSDT.aml Edited July 18, 2020 by Killuminati91
R-88 Posted August 27, 2020 Posted August 27, 2020 On 4/3/2020 at 7:03 PM, MaLd0n said: first post This is My patch and my SSDT-2, i dont understand why the red parts can't work.... With Mojave this patch was perfect...there is a must way to indicate INTO METHOD LABEL?? into definitionblock code_regex . insert begin Method (B1B2, 2, NotSerialized) { Return(Or(Arg0, ShiftLeft(Arg1, 8))) }\n end; into scope label \_SB.PCI0.LPCB.H_EC code_regex BA1T,\s+16, replace_matched begin B1T0,8, B1T1,8, end; into scope label \_SB.PCI0.LPCB.H_EC code_regex BA2T,\s+16, replace_matched begin B2T0,8, B2T1,8, end; into scope label \_SB.PCI0.LPCB.H_EC code_regex BA3T,\s+16, replace_matched begin B3T0,8, B3T1,8, end; into scope label \_SB.PCI0.LPCB.H_EC code_regex BA4T,\s+16, replace_matched begin B4T0,8, B4T1,8, end; into scope label \_SB.PCI0.LPCB.H_EC code_regex BA5T,\s+16, replace_matched begin B5T0,8, B5T1,8, end; into scope label \_SB.PCI0.LPCB.H_EC code_regex BA6T,\s+16, replace_matched begin B6T0,8, B6T1,8, end; into method label _BIF code_regex ECR2\s+\(RefOf\s+\(BA1T\)\), replaceall_matched begin B1B2(B1T0,B1T1), end; into method label _BIF code_regex ECR2\s+\(RefOf\s+\(BA2T\)\), replaceall_matched begin B1B2(B2T0,B2T1), end; into method label _BIF code_regex ECR2\s+\(RefOf\s+\(BA3T\)\), replaceall_matched begin B1B2(B3T0,B3T1), end; into method label _BIF code_regex ECR2\s+\(RefOf\s+\(BA4T\)\), replaceall_matched begin B1B2(B4T0,B4T1), end; into method label _BIF code_regex ECR2\s+\(RefOf\s+\(BA5T\)\), replaceall_matched begin B1B2(B5T0,B5T1), end; into method label _BIF code_regex ECR2\s+\(RefOf\s+\(BA6T\)\), replaceall_matched begin B1B2(B6T0,B6T1), end; into method label _BST code_regex ECR2\s+\(RefOf\s+\(BA1T\)\), replaceall_matched begin B1B2(B1T0,B1T1), end; into method label _BST code_regex ECR2\s+\(RefOf\s+\(BA2T\)\), replaceall_matched begin B1B2(B2T0,B2T1), end; into method label _BST code_regex ECR2\s+\(RefOf\s+\(BA3T\)\), replaceall_matched begin B1B2(B3T0,B3T1), end; into method label _BST code_regex ECR2\s+\(RefOf\s+\(BA5T\)\), replaceall_matched begin B1B2(B5T0,B5T1), end; # utility methods to read/write buffers from/to EC by RehabMan into method label RE1B parent_label \_SB.PCI0.LPCB.H_EC remove_entry; into method label RECB parent_label \_SB.PCI0.LPCB.H_EC remove_entry; into scope label \_SB.PCI0.LPCB.H_EC insert begin Method (RE1B, 1, NotSerialized)\n {\n OperationRegion(ERAM, EmbeddedControl, Arg0, 1)\n Field(ERAM, ByteAcc, NoLock, Preserve) { BYTE, 8 }\n Return(BYTE)\n }\n Method (RECB, 2, Serialized)\n {\n ShiftRight(Arg1, 3, Arg1)\n Name(TEMP, Buffer(Arg1) { })\n Add(Arg0, Arg1, Arg1)\n Store(0, Local0)\n While (LLess(Arg0, Arg1))\n {\n Store(RE1B(Arg0), Index(TEMP, Local0))\n Increment(Arg0)\n Increment(Local0)\n }\n Return(TEMP)\n }\n end; # patch 256 bit SMBD register (fixes by RehabMan) into scope label \_SB.PCI0.LPCB.H_EC code_regex (SMBD,)\s+(256) replace_matched begin SMBX,%2,//%1%2 end; into method label SMBR code_regex \(SMBD, replaceall_matched begin (RECB(0x44,256), end; #EOF SSDT-2.aml
Administrators MaLd0n Posted August 27, 2020 Administrators Posted August 27, 2020 use rehabman maciasl version for apply that -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
R-88 Posted August 27, 2020 Posted August 27, 2020 (edited) same problem I have to figure out how to indicate the _BIF method and _BST MaciASL recognizes the patch but doesn't know where to apply it, any suggestions? into method label _BIF code_regex ECR2\s+\(RefOf\s+\(BA1T\)\), replaceall_matched begin B1B2(B1T0,B1T1), end; into method label _BST code_regex ECR2\s+\(RefOf\s+\(BA1T\)\), replaceall_matched begin B1B2(B1T0,B1T1), end; Edited August 27, 2020 by R-88
R-88 Posted August 28, 2020 Posted August 28, 2020 17 hours ago, MaLd0n said: use rehabman maciasl version for apply that Please try to solve this errors, if i fix the SAT0 error the patch have 24 errors, if i can't fix sat0 the patch is working...? DSDT-PATCH.zip DSDT.dsl.zip
Administrators MaLd0n Posted August 28, 2020 Administrators Posted August 28, 2020 Bro, battery patch u need loose some hours on that if ur patch is missing in rehabman repo u need pay attention in embedded controller device too, if u use ec0 to ec for example, u need change it in patch too before apply -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
R-88 Posted August 28, 2020 Posted August 28, 2020 31 minutes ago, MaLd0n said: Bro, battery patch u need loose some hours on that if ur patch is missing in rehabman repo u need pay attention in embedded controller device too, if u use ec0 to ec for example, u need change it in patch too before apply I’ve wrote my patch by myself. It is in the rehab repository but can’t work on opencore. My original patch was made for ssdt1. Now with opencore I’ve extracted new ACPI and I have find the embedded on ssdt2. This is not clear, why it is changed?? my dsdt and ssdt work on clover but not on opencore. Why??
Administrators MaLd0n Posted August 28, 2020 Administrators Posted August 28, 2020 Just now, R-88 said: my dsdt and ssdt work on clover but not on opencore. Why?? the best is patch in Opencore and work in opencore/clover opencore is new, need many improvements about things -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
R-88 Posted August 28, 2020 Posted August 28, 2020 (edited) 13 minutes ago, MaLd0n said: the best is patch in Opencore and work in opencore/clover opencore is new, need many improvements about things Ok so now I use opencore I will send you a new runme and a will work on a new dsdt Edited August 28, 2020 by R-88
R-88 Posted August 28, 2020 Posted August 28, 2020 (edited) 6 hours ago, MaLd0n said: the best is patch in Opencore and work in opencore/clover opencore is new, need many improvements about things ok opencore work, we fix first the dsdt and after i will fix the battery please consider i have my usbPort.kext i've extract all necessary http://gofile.me/6EH67/4N0YZgkUq http://gofile.me/6EH67/bD2YRxH8T Edited August 28, 2020 by R-88
Administrators MaLd0n Posted August 29, 2020 Administrators Posted August 29, 2020 3 hours ago, R-88 said: ok opencore work, we fix first the dsdt and after i will fix the battery DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
R-88 Posted September 5, 2020 Posted September 5, 2020 On 8/29/2020 at 3:34 AM, MaLd0n said: DSDT.aml.zip 35.59 kB · 3 downloads There are ACPI errors 1. You have changed H_EC to EC, this does not allow my battery patch to work 2. My battery patch applies to the SSDT-2, not the DSDT 3. Using Clover my patch worked together with your DSDT, why doesn't it work with Opencore? 4. I have included the SysReport with native DSDT and SSDT extracted with Opencore and new SendMe http://gofile.me/6EH67/BpyStCARz
Administrators MaLd0n Posted September 5, 2020 Administrators Posted September 5, 2020 1 hour ago, R-88 said: Using Clover my patch worked together with your DSDT, why doesn't it work with Opencore? Opencore don't override secondary tables automatic like clover clover identify table and override. we dont need made any change for that. opencore no. u need drop OEM table in config.plist and add ur new table -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
R-88 Posted September 6, 2020 Posted September 6, 2020 (edited) u need drop OEM table in config.plist and add ur new table Thanx for the reply!!! But is not clear. In my old Clover config i can't have any table OEM selected... I attach the old EFI Clover and the New EFI Opencore, i don't understand what you tell me to do, sorry... http://gofile.me/6EH67/qGR1IJyjB http://gofile.me/6EH67/vPhXFmqpj !!! IN THE PREVIOUS DSDT MADE BY YOU I HAVE H_EC NOT EC, also in all my SSDT I HAVE H_EC, in fact if I don't change H_EC in EC in the SSDT-1 the battery is not detected. Can't you leave H_EC on DSDT and I patch H_EC to EC ?? Send me MacBook-Pro-2.home-life.hub.zip Edited September 6, 2020 by R-88
Administrators MaLd0n Posted September 7, 2020 Administrators Posted September 7, 2020 u need remove this rename, use ssdt olarila, reboot and extract new 10 hours ago, R-88 said: But is not clear. In my old Clover config i can't have any table OEM selected Clover is a complete bootloader with all solutions. Opencore is new and need many improvements for advanced users -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
R-88 Posted September 7, 2020 Posted September 7, 2020 8 hours ago, MaLd0n said: u need remove this rename, use ssdt olarila, reboot and extract new Clover is a complete bootloader with all solutions. Opencore is new and need many improvements for advanced users here it is!! Send me MacBook-Pro-2.zip
Administrators MaLd0n Posted September 7, 2020 Administrators Posted September 7, 2020 4 hours ago, R-88 said: here it is!! DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
R-88 Posted September 7, 2020 Posted September 7, 2020 (edited) 2 hours ago, MaLd0n said: DSDT.aml.zip 35.62 kB · 1 download You are the best! As you can see now that H_EC exists my battery works and also see the power adapter! There are some ACPI errors that I don't understand how to fix them... I attach a new send me, consider that I am using OC Debug let me know P.S. Can't power off but reboot Send me MacBook-Pro-2.zip Picture.png.zip Edited September 7, 2020 by R-88
Administrators MaLd0n Posted September 7, 2020 Administrators Posted September 7, 2020 looks good ignore acpi warnings. is about battery -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
