9 minutes ago, mathewgx said:
There is no patch for my laptop (DELL 5570).
ma ny dells work with only virtualsmc and battery plugin
Sometimes battery jumps from 40% or so to 5-6% instantly.
i have changed battery (original) and the problem persists.
And I don't know if there is something wrong with my configuration or a hardware problem.
11 hours ago, leafbottom said:
Thanks for the reply. I've done as asked. Files attached.
Ok Maldon and Onemanosx,
thanks for the guide but i need some help.
I took the first step and I have several errors, if I proceed with the second step it doesn't work ...
This is my first step:
into device label EC code_regex B2RC,\s+16, replace_matched begin 2RC0,8, 2RC1,8, end;
into device label EC code_regex B2FC,\s+16, replace_matched begin 2FC0,8, 2FC1,8, end;
into device label EC code_regex B2FV,\s+16, replace_matched begin 2FV0,8, 2FV1,8, end;
into device label EC code_regex B2DI,\s+16, replace_matched begin 2DI0,8, 2DI1,8, end;
into device label EC code_regex B2CI,\s+16, replace_matched begin 2CI0,8, 2CI1,8, end;
into device label EC code_regex B2DC,\s+16, replace_matched begin 2DC0,8, 2DC1,8, end;
into device label EC code_regex B2DV,\s+16, replace_matched begin 2DV0,8, 2DV1,8, end;
I have too many errors, and the first (PICM) is not in the EC
Can I have a suggestion on how to proceed?
I attach the dsdt without my modification (point 1)
Try it yourself
DSDT.zip
Can someone help me to patch battery on my laptop (Dell 5570)?
In dsdt there are BAT0 and BAT1.
I've read the guide but it is too complicated for me.
Could someone help me?
Battery percentage droping suddenly from 40-45% to 5-6% and it is driving me crazy.
Here are the debug files if someone will.
Thanks in advance.
debug.zip
Can someone please help me getting my battery status and % work again before adding my second ssd it was working Fine with this DSDT everything was working fine DSDTBeforeSecondSSDInstalled.zip  Then I have installed a second SSD and i couldn't boot up into my hack then i have changed DSDT to this DSDTAfterSecondSSDInstalled.zip i managed to boot to my hack again but my battery status isn't working so can anyone helps me getting my battery back to work again
On 5/8/2020 at 5:19 AM, divyesh jaiswal said:
try with only virtualsmc and battery plugin first
check first post
@MaLd0n I have tried to follow the steps and couldn't do it more than once one of my tries i have corrupted my dsdt file and another one i have destroyed it if you can help me which batch would fit with my laptop brand Eluktronics Mech 15 G2Rx of the ones provided by http://raw.github.com/RehabMan/Laptop-DSDT-Patch/master that would be a great help and if it's not available if you can help me doing it that would be a great help and Thanks in advance for your time and help.
39 minutes ago, mjoku said:
first try with virtualsmc and battery plugin
@MaLd0n both of them are already installed with all of virtualSMC plugins and all of them working except battery indicator and i have tried more uninstalling them and reinstalling them again and still no Changes :(
inside device ec
u have many work
@MaLd0n isn't there a patch fixing this part for me or should i keep trying myself on specific DSDT and saving a backup one so i can boot if there's something went wrong ?
go to step by step, save, backup
@MaLd0n, It doesn't work with only virtualSMC. I fixed 16-bit and 32-bit  registers, but, I don't know how to fix 128-bit registers. Please help.
just / many times
16 hours ago, MaLd0n said:
Sei nem pra onde que vai! :D
Eu tentei usar patch com o Miasl, usando o path do Razerblade 15(por ter a configuração parecida com o Samsung Odyssey) mas não ativou a bateria :(
Me indicaria algum patch desse site?:
GitHub - RehabMan/Laptop-DSDT-Patch: Common DSDT patches for Ivy/Sandy/Haswell laptops for running OS X
Configuração do note:
i7 9750H
Nvidia GTX 1650
Cannon Lake PHC\Coffee Lake-H
Trackpad I2C HID (Elan)
Intel Wireless AC-9560
Realtek ALC 256
HahAhAH
How can I do this, mano?
My Battery don't appear nas preferências do sistema
Edited by Zarach
HahAhAH
