@onemanosx , can you patch my dsdt?
Cannot find and ERAM values.
you are expected to find embeddedcontrol
Donate
Gitter Chat
MSI B360 Gaming Arctic
[ref]Wizzard[/ref], new laptop? You can find the working DSDT in page 4 if you are still using your teclast
Yes, still Teclast. Funny is, that it does not boot with those DSDT. This is the last thing I see.
Ok. Got it.
Seems to me that I don't need any battery patch?
Could you confirm?
If you are still using your old laptop, I had established that your DSDT need no further patching. Here is the post https://Olarila.com/forum/viewtopic.php?p=71249#p71249
Added in 11 minutes 54 seconds:
You need to enable H_EC to EC patch in clover. If you have a patched DSDT, you should place it in Clover/ACPI/Patched folder. It also looks like you need I2C patch in your clover.
Added in 9 minutes 35 seconds:
[ref]SemoB[/ref], Can you show the patches in txt file instead? I just did a quick look and found you did not patch for CYCN. You might want to check your work again and be extra attentive.
Donate
Gitter Chat
Thanks! Just enabled H_EC to EC patch and it works!
Aha, that was it. I missed CYCN. Patched it and now it works! Thanks, [ref]onemanosx[/ref]. Is there anything else I need to do regarding power/battery management?
I didnt check for your other settings but good job on your battery patching! Congrats!
Added in 39 seconds:
:mrgreen:
Donate
Gitter Chat
[ref]TheFahmi[/ref], :shock:
My Laptop see the battery without any kext....i have only patched my SSDT with my own patch.
This is normal?
I'm on Catalina
:poke
Donate
Gitter Chat
[ref]R-88[/ref], If you would have said, my laptop sees battery status without patching DSDT but using SSDT patching, I would have understood and it is possible. For some laptops even has working battery status without any patching done and this too is plausible. But, to say it works without kext on a hackintosh is something unheard of.
Donate
Gitter Chat
my friend you are completely right!
I had not seen VirtualSMC plugins! This is the answer, thanks in any case for the clarification
