Wrong link to MaciASL. Please, fix it.
Fixed! Thanks!
Donate
Gitter Chat
MSI B360 Gaming Arctic
when I press patch it shows me nothing, there's no text no nothing its completely empty
What are you trying to patch specifically?
Donate
Gitter Chat
I was just following the steps for the battery problem and it said press patch and scroll down to bat
Did you find a patch specific for your laptop?
Donate
Gitter Chat
no, because it shows me nothing when I go into patch and look for bat. everything is blank.
Then you will need to do your custom patch.
Donate
Gitter Chat
<IMGUR id="b7b2nJ4"><a href=https://i.imgur.com/b7b2nJ4.png' alt='IMGUR>'>
hallo onemanosx,
I follow your tutorial, but i confused how to change it on my lenovo thinkpad e130
i need help
tks
my laptop thinkpad E130
intel core i5, RAM 8GB, INTELHD 4000 (High Sierra)
DSDT_PATCHACPI_Bat_err.zip
<IMGUR id="9drnl3p"><a href=https://i.imgur.com/9drnl3p.png' alt='IMGUR>'>
[ref]lasak12[/ref], Can you upload your original DSDT.aml and your intended custom patch?
I cant tell whats going on by just looking at your patched DSDT.
Donate
Gitter Chat
yes, i can
this is DSDT Origin mylaptop
trims
Since you did not upload your custom patch, can you list the bit integers that requires patching from the embeddedcontrol?
Donate
Gitter Chat
I'm Sorry, just replied
Yes, this my list
SBRC, 16,
SBFC, 16,
SBAE, 16,
SBRS, 16,
SBAC, 16,
SBVO, 16,
SBAF, 16,
SBBS, 16
SBMD, 16,
SBCC, 16
SBDV, 16,
SBOM, 16,
SBSI, 16,
SBDT, 16,
SBSN, 16
SBCH, 32
SBMN, 128
SBDN, 128
Correct me if i wrong
trims
[ref]lasak12[/ref], You are only expected to patch integers which are being called again in DSDT. SBRC as an example, is not being called anywhere else in DSDT. So, this is not required.
You also missed a few integers. SMD0 is an example of that.
Donate
Gitter Chat
[ref]darkbluecode[/ref], Have you read the guide and troubleshoot what you might have missed?
Donate
Gitter Chat
I can't compile the DSDT.aml bc it shows the errors...
Solved the compile error for you.
Donate
Gitter Chat
[ref]Wizzard[/ref], new laptop? You can find the working DSDT in page 4 if you are still using your teclast
Donate
Gitter Chat
