Why is CPU not booting with the same frequency in OSX every time? Sometimes when it boots it has 3.66Ghz as native MAX and sometimes it has 3.70Ghz. What could be the reason? Anything to real bother about? Anyone else seen this? its ivy bridge Xeon E5 with SSDT from ssdtprgen all turbo modes and idle modes working.
is common, cpu power management
[ref]xayide[/ref], for check if work, first check in ioreg, cpu
[ref]xayide[/ref], x86plat is load, is good
u can check log too, check if u see error, etc
log show --last boot --style syslog
[ref]xayide[/ref], :cap
Log seems OK. Nothing stands out. Maybe its the base frequency that is not the same all times.....ie spread spectrum or something...
MacPro61:~ admin$ log show --last boot --style syslog | grep CPU
2018-12-29 12:41:18.727404+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) AICPM::start: calling i386_pmRegister()
2018-12-29 12:41:18.727459+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) AICPM::start: back from i386_pmRegister()
2018-12-29 12:41:18.727459+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) AICPM::start: calling i386_pmThreadInit()
2018-12-29 12:41:18.895451+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
2018-12-29 12:41:18.895457+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
2018-12-29 12:41:18.895640+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPICPU: ProcessorId=4 LocalApicId=4 Enabled
2018-12-29 12:41:18.895651+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPICPU: ProcessorId=6 LocalApicId=6 Enabled
2018-12-29 12:41:18.895664+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPICPU: ProcessorId=1 LocalApicId=1 Enabled
2018-12-29 12:41:18.895677+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPICPU: ProcessorId=3 LocalApicId=3 Enabled
2018-12-29 12:41:18.895691+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPICPU: ProcessorId=5 LocalApicId=5 Enabled
2018-12-29 12:41:18.895701+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPICPU: ProcessorId=7 LocalApicId=7 Enabled
2018-12-29 12:41:18.963902+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) CPU Data: size = 4, alignment = 64
2018-12-29 12:41:18.963903+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) Pkg Data: size = 0
2018-12-29 12:41:18.963904+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) CPU Data: size = 4, alignment = 64
2018-12-29 12:41:18.963904+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) Pkg Data: size = 0
2018-12-29 12:41:18.963905+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) CPU Data: size = 4, alignment = 64
2018-12-29 12:41:18.963906+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) Pkg Data: size = 0
2018-12-29 12:41:18.963906+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) CPU Data: size = 4, alignment = 64
2018-12-29 12:41:18.963907+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) Pkg Data: size = 0
2018-12-29 12:41:18.963908+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) CPU Data: size = 4, alignment = 64
2018-12-29 12:41:18.963908+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) Pkg Data: size = 0
2018-12-29 12:41:18.963909+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) CPU Data: size = 4, alignment = 64
2018-12-29 12:41:18.963910+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) Pkg Data: size = 0
2018-12-29 12:41:18.963910+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) CPU Data: size = 4, alignment = 64
2018-12-29 12:41:18.963911+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) Pkg Data: size = 0
2018-12-29 12:41:18.963912+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) CPU Data: size = 4, alignment = 64
2018-12-29 12:41:18.963912+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) Pkg Data: size = 0
2018-12-29 12:41:18.968754+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) AICPM::start: back from i386_pmThreadInit()
2018-12-29 12:41:18.968755+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) AICPM::start: calling registerService()
2018-12-29 12:41:18.968764+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) AICPM::start: back from registerService()
2018-12-29 12:41:18.968765+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) AppleIntelCPUPowerManagement: ready
2018-12-29 12:41:19.280326+0100 localhost kernel[0]: (kernel) CPUSensors: CPU family 0x6, model 0x3e, stepping 0x4, cores 4, threads 8, TJmax 100
2018-12-29 12:41:19.280331+0100 localhost kernel[0]: (kernel) CPUSensors: setting platform keys to [d8 ]
2018-12-29 12:41:19.280362+0100 localhost kernel[0]: (kernel) CPUSensors: base CPU multiplier is 37
2018-12-29 12:41:19.280419+0100 localhost kernel[0]: (kernel) CPUSensors: started
2018-12-29 12:41:19.306261+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) hpet_init: Frequency = 14.318179MHz, hpetCvtt2n = 00000045.D75E0F7F, hpetCvtn2t = 00000000.03AA5B32
2018-12-29 12:41:19.306293+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) AppleIntelCPUPowerManagement: Turbo Mode enabled
2018-12-29 12:41:19.306296+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) AppleIntelCPUPowerManagement: Turbo Ratios 0002
2018-12-29 12:41:19.306297+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) AppleIntelCPUPowerManagement: SMT enabled
2018-12-29 12:41:19.306299+0100 localhost kernel[0]: (AppleIntelCPUPowerManagement) AppleIntelCPUPowerManagement: (built 20:32:47 Nov 12 2018) initialization complete
2018-12-29 12:41:27.889789+0100 localhost kernel[0]: (pmtelemetry) Unsupported CPU
2018-12-29 12:41:27.889794+0100 localhost kernel[0]: (pmtelemetry) Unsupported CPU
2018-12-29 12:41:28.426869+0100 localhost kernel[0]: (IOPlatformPluginFamily) IOPPF: AppleIntelCPUPowerManagement mode
2018-12-29 12:41:28.426871+0100 localhost kernel[0]: (IOPlatformPluginFamily) IOPPF: AppleIntelCPUPowerManagement mode
