onemanosx Posted January 1, 2019 Posted January 1, 2019 the pnlf method is already in your dsdt Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
broadw3ll Posted January 1, 2019 Author Posted January 1, 2019 Thats what I think... idk where is the problem now. in other things was able to work the card reader with this kext in the Clovers folder Sinetek-rtsx.kext.zip
onemanosx Posted January 1, 2019 Posted January 1, 2019 [ref]broadw3ll[/ref], cool that your card reader is working! Congrats! Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
broadw3ll Posted January 1, 2019 Author Posted January 1, 2019 Yes!!! Bro but I'm still facing problems with the Nvidia buildin panel brightness, also I have discovered by searching and trying than the HDMI audio isn't supported, only it's supported with DP. So I if you know anything or suggest about the brightness I would be glad if heard it
onemanosx Posted January 1, 2019 Posted January 1, 2019 Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
broadw3ll Posted January 1, 2019 Author Posted January 1, 2019 Now i made the HDMI audio work, the speakers sounds nice its thing of time to check the performance... I use this kext and patch with VOODOOHDA I'm gonna attempt to generate my power management with this guide:(https://www.tonycrapx86.com/threads/quick-guide-to-generate-a-ssdt-for-cpu-power-management.177456/) (https://github.com/acidanthera/CPUFriend/blob/master/Instructions.md) because of the things that MaLd0n suggested SSDT with Pike Script and generate data with CpuFriend script, add in Pike Ssdt with _DSM" actually it is kind of messy UPDATE:I check with a few songs and probably its sound thing of nothing better the apple alc but Im having problems with my jack 3.5mm output so I will use the voodoo one unless someone suggested me something better. HDMIAudio.kext_.zip SSDT-HDMI-NVIDIA-PEG0.aml_.zip
broadw3ll Posted January 2, 2019 Author Posted January 2, 2019 (edited) hello I have checked this guide: (https://github.com/Piker-Alpha/ssdtPRGen.sh) but my processor its unknown by the generator as is showed in the output of terminal in the screenshot I'm gonna attach the intel info.kext output and the missing data of the generator in termina....if it can help in something... https://ark.intel.com/products/97185/Intel-Core-i7-7700HQ-Processor-6M-Cache-up-to-3-80-GHz- AppleIntelInfo output.rtf procesor data 7700hq.docx Edited January 2, 2019 by Guest
onemanosx Posted January 2, 2019 Posted January 2, 2019 [ref]broadw3ll[/ref], Congrats of your success to activate your HDMI audio! Which gives me the idea that maybe.. just maybe if you switch to the old graphics driver NvidiaGraphicsFixup.kext instead of Whatevergreen.kext, you might be able to activate your brightness slider with the help of Applebacklightfixup.kext. Try it! - https://github.com/lvs1974/NvidiaGraphicsFixup/releases - https://bitbucket.org/RehabMan/applebacklightfixup As for poor laptop sound, if you are using AppleALC.kext you might want to explore other layout id available for your ALC295 codec. Check out the other available layout-id - https://github.com/acidanthera/AppleALC/tree/master/Resources/ALC295 Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
broadw3ll Posted January 2, 2019 Author Posted January 2, 2019 Hello onemanosx that trident change nothing I have check all the comments of the guide that I attach and there someone who says the brightness work in his case doing this: fix XOSI add device PNLF rename GFX0 to _GFX both DSDT and SSDTs rename PEGP to GFX0 both DSDT and SSDTs add device (HDAU) under PEG0 return (one) under device (EDP1) I remember and the pnlf device its add as u did and also the other things as I guess but it seems that also I don t have ssdt because I can't generated the power management one because my processor its unsupported as I mentioned in my last post the, only ssdt that I'm using is this one SDT-XOSI.aml from here (https://www.insanelymac.com/forum/topic/323010-please-help-me-fix-brightness-control-nvidia-graphics-only-laptop/?page=8) from the commentary made by male_hxm do u have any idea ? thnx for all
onemanosx Posted January 2, 2019 Posted January 2, 2019 [ref]broadw3ll[/ref], for later build like yours PM using plugin-type=1 in clover is suffice. I am using that clover patch with no problem. SSDT-XOSI is a windows patch, where I believe, your DSDT is already equipped with. Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
broadw3ll Posted January 2, 2019 Author Posted January 2, 2019 it seems I have _osi the suggest to change it, I have check in th dsdt thats why I though if its necessary I'm gonna attach my run_me file if no just ignore it Send me Luiss-MacBook-Pro-2.zip
onemanosx Posted January 3, 2019 Posted January 3, 2019 Your DSDT is already patched with windows 10 if i remember correctly. Unless you want to use other windows version for whatever reasons, you may do so. Check the ssdt osi file what windows version is it supposed to patch? Edit: I had read in other laptop versions, patching with win8 OSI enabled trackpad for ELAN 1200. Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
broadw3ll Posted January 3, 2019 Author Posted January 3, 2019 Hmmm so there's not the problem I gonna try to digg a little bit about that problem related: I have a windows 8 copy lol
onemanosx Posted January 3, 2019 Posted January 3, 2019 Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
broadw3ll Posted January 4, 2019 Author Posted January 4, 2019 hello onemanosx I get stuck in the cpufriend guide because it says "NOTE: The created kext/ssdt is located in the current working directory. --file should be a complete plist from--/System/Library/Extensions/IOPlatformPluginFamily.kext/Contents/PlugIns/ACPI_SMC_PlatformPlugin.kext/Contents/Resources or /System/Library/Extensions/IOPlatformPluginFamily.kext/Contents/PlugIns/X86PlatformPlugin.kext/Contents/Resources with certain modifications (Otherwise why do you even need CPUFriend?) instead of something like a raw FrequencyVectors entry." in my case is System/Library/Extensions/IOPlatformPluginFamily.kext/Contents/PlugIns/X86PlatformPlugin.kext/Contents/Resources but... which one of all of them is a "complete plist" I have managed to use the Pike Script with the beta one but y need to now generate the other one to merge them but I'm having problem with that "file"
onemanosx Posted January 4, 2019 Posted January 4, 2019 [ref]broadw3ll[/ref], I am not yet familiar with CPU friend. Do you have any write up on how to configure it? The only thing I can vaguely remember is to change the kexts's info.plist CPU core count to match your system. Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
broadw3ll Posted January 4, 2019 Author Posted January 4, 2019 Onemanosx this is the only "installation" post that it in the GitHub folder https://github.com/acidanthera/CPUFriend/blob/master/Instructions.md
onemanosx Posted January 5, 2019 Posted January 5, 2019 [ref]broadw3ll[/ref], See my guide here https://Olarila.com/forum/viewtopic.php?f=28&t=8268 Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
broadw3ll Posted January 6, 2019 Author Posted January 6, 2019 Thanx for the guide very understandable to be honest... i have read about the option plugin type some threads say about disable it, too I get confuse. right now this is how it looks my config plist
onemanosx Posted January 6, 2019 Posted January 6, 2019 I disabled the plugin type when I use pike's ssdt + cpufriend.kext Yeah, I figured someone gotta do a detailed guide Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
