Administrators MaLd0n Posted August 4, 2020 Administrators Posted August 4, 2020 5 hours ago, kobiandy said: To the best of my knowledge everything works except the wifi(which is because of unsupported hardware), Ethernet and trackpad both of which I can't live with. this folder is a mistery u need a clean and correct renames and config -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
nayga73 Posted August 8, 2020 Posted August 8, 2020 (edited) Morning guys, I'm not one for asking for help, but this time I'm needing the skills of someone to get my Trackpad and Keyboard up and running. I have a Probook 440 G5 using OC 0.6.1 i5 8th Gen KBL, I have everything else working, Bluetooth,wifi etc etc, just can't get this bloody thing up and running. After I managed to get battery stats working, the keyboard and trackpad failed to work, so not sure if it is to do with that??If I use VoodooI2C kext or VoodooPS2 kexts, my machine fails to load I've looked through this thread and tried the pinning and still not working, worse thing is I know the trackpad is supported!!!I'm so near, but yet so far If someone could kindly take a look at this to see where I've gone wrong, that would be smashing RunMe: https://filebin.net/e2h751kz8kt72dcq many thanks in advance nayga73 Edited August 8, 2020 by nayga73
limeblue Posted August 8, 2020 Posted August 8, 2020 Good day, I need help for my Hackintosh to enable i2c trackpad device which syna2b33. I have a Lenovo ideapad 330-15ikb i3 7th gen cpu, with intel hd graphics 620. Attached file through Runme App: https://filebin.net/sj3abk6dqa7ow89l
Administrators MaLd0n Posted August 8, 2020 Administrators Posted August 8, 2020 10 hours ago, nayga73 said: Morning guys, DSDT.aml.zip 5 hours ago, limeblue said: Good day, first u need a good folder use only ec0 to ec and _sta rtc fix in acpi renames patch -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
nayga73 Posted August 8, 2020 Posted August 8, 2020 1 hour ago, MaLd0n said: DSDT.aml.zip 50.41 kB · 1 download Hi mad0n, I have used the patched DSDT but sadly it doesn't go past AppleIntelpssI2CController-1 : :_notificationPublishedHandler: getChannelNumber failed AppleIntelpssI2CController-1 : :_notificationPublishedHandler: getChannelNumber failed AppleIntelpssI2CController-1 : :_notificationPublishedHandler: getChannelNumber failed I feel like throwing the thing out of the window, but then I wouldn't have anything to tinker with If there is anything else you can do, it's greatly appreciated nayga73
Administrators MaLd0n Posted August 9, 2020 Administrators Posted August 9, 2020 5 hours ago, nayga73 said: but sadly it doesn't go past u need rename embedded controller to ec or inject ec device -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
limeblue Posted August 9, 2020 Posted August 9, 2020 20 hours ago, MaLd0n said: DSDT.aml.zip 50.41 kB · 1 download first u need a good folder use only ec0 to ec and _sta rtc fix in acpi renames patch Sorry sir I'm just a noob, what do you mean need a good folder? About that use only ec0 to ec, does it mean I will disable the others in DSDT patches in clover? and where is _sta rtc fix in ACPI, I only see Fix RTC checkbox.
Administrators MaLd0n Posted August 9, 2020 Administrators Posted August 9, 2020 1 hour ago, limeblue said: Sorry sir I'm just a noob, what do you mean need a good folder? About that use only ec0 to ec, does it mean I will disable the others in DSDT patches in clover? and where is _sta rtc fix in ACPI, I only see Fix RTC checkbox. remove all renames and add ec0 to ec and _sta rtc fix Quote <dict> <key>Find</key> <data>RUMwXw==</data> <key>Replace</key> <data>RUNfXw==</data> <key>Disabled</key> <false/> <key>Comment</key> <string>change EC0 to EC</string> </dict> <dict> <key>Find</key> <data>oAqTU1RBUwE=</data> <key>Replace</key> <data>oAqRCv8L//8=</data> <key>Disabled</key> <false/> <key>Comment</key> <string>Fix Boot Stuck</string> </dict> -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
nayga73 Posted August 9, 2020 Posted August 9, 2020 (edited) Hi Mald0n, I've added in the EC patch but still freezing upon trying to boot, I have linked my EFI:- https://filebin.net/ewrmf65bblm754cl Would you kindly take a look at this for me to make sure I have everything right?I haven't added in the patched DSDT you sent me, I have put one prior to being patched.I'm pulling my hair out nayga73 Edited August 9, 2020 by nayga73
nayga73 Posted August 15, 2020 Posted August 15, 2020 Hi MAld0n, I've still been trying to get this trackpad and keyboard to work without success, did you get a chance to have a look at my config at all? K/R nayga73
Administrators MaLd0n Posted August 15, 2020 Administrators Posted August 15, 2020 6 hours ago, nayga73 said: Hi MAld0n, compile last voodooi2c kext. have support now -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ronaldocesar Posted August 16, 2020 Posted August 16, 2020 On 8/15/2020 at 1:15 PM, MaLd0n said: compile last voodooi2c kext. have support now Hi @MaLd0n, I have a VAIO FE14 with i3 8th gen, I already tried lots and lots of things and I can't get my I2C touchpad to work (I believe it's a Synaptics). Could you please send me the file? RunMe: https://drive.google.com/file/d/1NEe3qjxSIZH653tlAjvzH4qJgTwbGISe/view?usp=sharing Thanks so much!
Administrators MaLd0n Posted August 16, 2020 Administrators Posted August 16, 2020 45 minutes ago, ronaldocesar said: Hi @MaLd0n, faz um teste com essa pasta no usb. se funcionar extrai novo sendme https://easyupload.io/zm92bd -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ronaldocesar Posted August 17, 2020 Posted August 17, 2020 22 hours ago, MaLd0n said: faz um teste com essa pasta no usb. se funcionar extrai novo sendme https://easyupload.io/zm92bd Obrigado pelo envio Fiz o teste com essa EFI, porém o touchpad continua sem funcionar, conforme solicitado, extrai um novo report do RunMe: https://drive.google.com/file/d/1lrsQE2sx307U6efZTQdWuawzp5BA9e52/view?usp=sharing Obrigado!
Administrators MaLd0n Posted August 17, 2020 Administrators Posted August 17, 2020 21 minutes ago, ronaldocesar said: Fiz o teste com essa EFI, porém o touchpad continua sem funcionar, conforme solicitado, extrai um novo report do RunMe: Archive.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ronaldocesar Posted August 17, 2020 Posted August 17, 2020 38 minutes ago, MaLd0n said: Archive.zip 43.62 kB · 2 downloads O procedimento seria só substituir o config.plist e colocar o DSDT na EFI/CLOVER/ACPI/patched né? Infelizmente tentei aqui mas não foi ?
Administrators MaLd0n Posted August 17, 2020 Administrators Posted August 17, 2020 5 minutes ago, ronaldocesar said: O procedimento seria só substituir o config.plist e colocar o DSDT na EFI/CLOVER/ACPI/patched né? Infelizmente tentei aqui mas não foi ? novo ioreg -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ronaldocesar Posted August 17, 2020 Posted August 17, 2020 12 minutes ago, MaLd0n said: novo ioreg https://drive.google.com/file/d/1jKrYXFhIdnKHj94NQ83CFcQfipcLbNuJ/view?usp=sharing
Administrators MaLd0n Posted August 17, 2020 Administrators Posted August 17, 2020 9 minutes ago, ronaldocesar said: https://drive.google.com/file/d/1jKrYXFhIdnKHj94NQ83CFcQfipcLbNuJ/view?usp=sharing está full load, se o trackpad não funciona...rip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ronaldocesar Posted August 17, 2020 Posted August 17, 2020 1 minute ago, MaLd0n said: está full load, se o trackpad não funciona...rip Puts que pena.. Obrigado!
