6 hours ago, Tomas Šaduikis said:
Have tried it already. didn't help. I've read it is something related to GPI0
check if bios/uefi setup have option advanced trackpad
Can anybody help me? plz
My Touchpad is recognized as a USB mouse and also, from time to time, "jumping", making its use quite inconvenient.
- 'Disable built-in trackpad when ...' doesn't even appear in my accessibility settings
- ACPI ID is TPD0
- APIC pin number: 0x57
- {// Pin list
        0x3f
- and I made the change to the _CRS method: Return (ConcatenateResTemplate (SBFB, SBFG))
Runme: https://drive.google.com/open?id=1gJdriMyezu9NHhbHpnOKPtuTLSRqAb0K
EDIT:
- Pode responder em portugues :D
- Estou usando Mojave no ideapad 330
Edited by luccasoli
5 hours ago, luccasoli said:
Acho que os pulos pararam, valeu!!!
Mas ainda é reconhecido como um mouse usb tradicional, sem gestos =c
Respondi duas vezes, sorry
Voltei a mexer agora no hackintosh e problema de touchpad dando alguns saltos apareceu novamente =c
veja se os devs do projeto i2c podem te ajudar
Hi all,
for start, u need know, i have some "functional OSX hacks done, but still i am rly noob, this community/page help me alot, also i donate some bucks.. for beer... :D i just need a little advice maybe, not sure.. seriously i am lost. I follow open topic, but cant get Trackpad to work. My machine is here:
my trackpad ACPI ID is TDP0, its Syna2852 according IOReg, IO Interrupt specifiers starts on DATA field with 53, so its highest than 47, then i follow second post here..
BUT there is my problem.. i dont know what software or how use/open/resave DSDT.aml
(dont have problem with do something wrong, bcoz i have functional USB3 SSD install and i can go back with my EFI any time)
some picture from IOReg and also also my Clover kexts folder:
Sni-mek-obrazovky-2020-02-13-v-9-22-25.p Sni-mek-obrazovky-2020-02-13-v-9-23-45.p Sni-mek-obrazovky-2020-02-13-v-9-25-23.p Sni-mek-obrazovky-2020-02-13-v-10-03-07.
Just for info: When i use VoodooI2CHID.kext, trackpad "works" but laggy, cursor auto moving, two or three fingers stop this moving, nothing show in Trackpad, still no trackpad here, but "works".
here also my Send_Me file:
http://s000.tinyupload.com/index.php?file_id=84319637018085960031
I appreciate any help, advice or you just kick me a bit to continue :P
Edited by intommy
Build 1: Intel i5-6600 Skylake, GA-B150m-D3H, 8GB DDR4, ASROCK Radeon RX 590 Phantom Gaming X 8G OC,  512GB - LENSE20512GMSP34MEAT2TA (NVMe) - windows / Patriot Burst 240 Sata macOS Catalina, Fractal Design Meshify C Mini Dark TG, Corsair RM650x, Catalina 10.15.4./ Win10  Build 2: Toshiba Tecra z40-c-11e, Intel Core i5 6200U Skylake, 8GB DDR3, Intel HD Graphics 520, Kingston UV500 240GB (SUV500/240G), BroadCom BCM94360CS2  + 12+6 Pin WIFI wireless card module to NGFF M.2,, Catalina 10.15.4  Build 3: Optiplex 790, Intel Core i3 (2nd Gen) 2120 / 3,3GHz, Intel Q65 Express, 8GB DDR3 (4x2GB), MSI GTX 760 - 2GB, Patriot Burst SSD 120GB, BroadCom BCM94360CS2  + 12+6 Pin WIFI wireless card module to NGFF M.2, Catalina 10.15.4. Build 4: Lenovo L340-15IRH Gaming Laptop - Type 81LK (81LK0034CK), Intel Core i5 9300H (2,40-4,10GHz), 8GB DDR4 2400MHz (1x8), Intel UHD Graphics 630, Catalina 10.15.4 / Windows 10 (Patriot Burst 240GB SATA3 SSD / M.2 PCIe SSD 512GB), DW1820a, atm not work: Wifi 5GHz, only 2,4 and BT.
2 hours ago, MaLd0n said:
wow, just.. wow.. i use "same" kext in clover/kexts/other not now, i just delete synaptics one, but when i put this two kexts Arquivo Comprimido.zip 140.42 kB · 0 downloads inside my clover(one replaced),
  • trackpad works :)
  • two fingers scroll
  • one finger tap
  • launchpad
atm still checking functionality,
anyway beer on way (again) :P  (dont drink and drive!) ??
Edited by intommy
about right button, ofc i know about using CTRL and click for right button, but is there a options for function right button like in windows? :P
  • two fingers click work like right button
Edited by intommy
extract new send_me
4 minutes ago, MaLd0n said:
extract new send_me
here is. :) thx
https://filebin.net/kmqn313mue5s1lo5
//also when i start laptop with ethernet cable conected got no internet, need re-plug cable, sometimes more times)
28 minutes ago, intommy said:
here is. :) thx
https://filebin.net/80e354gxbc3rewvq/CLOVER.zip?t=bljrcsfb
generate cpufriend
one-key-cpufriend.command.zip
1 hour ago, MaLd0n said:
Sound stop working.. :)
and with CPU friend i just need use lower frekvencies?  Normally is 1200-1300MHz they wrote or under 800MHz, also here about battery saving i use 2 - balance, but still is throttling
audio just inject via clover
2 hours ago, Tomas Šaduikis said:
Hi,
i patched ur dsdt, use my dsdt and apply ur patches
does not boot. stuck at applecredencialmanager
I managed to boot, but still no trackpad.
2020-02-14 12:49:31.269809+0100 0xc1       Default     0x0                  0      0    kernel: (kernel) VoodooGPIOCannonLakeLP::Loading GPIO Data for CannonLake-LP
2020-02-14 12:49:31.270408+0100 0xc1       Default     0x0                  0      0    kernel: (kernel) VoodooGPIOCannonLakeLP::VoodooGPIO Init!
2020-02-14 12:49:31.270670+0100 0xc1       Default     0x0                  0      0    kernel: (kernel) VoodooGPIOCannonLakeLP::VoodooGPIO Initializing Community 0
2020-02-14 12:49:31.270900+0100 0xc1       Default     0x0                  0      0    kernel: (kernel) VoodooGPIOCannonLakeLP::VoodooGPIO Initializing Community 1
2020-02-14 12:49:31.271241+0100 0xc1       Default     0x0                  0      0    kernel: (kernel) VoodooGPIOCannonLakeLP::VoodooGPIO Initializing Community 2
2020-02-14 12:49:31.271664+0100 0x76       Default     0x0                  0      0    kernel: (kernel) VoodooGPIOCannonLakeLP::GPIO Controller is already awake! Not reinitializing.
2020-02-14 12:49:31.351034+0100 0xf4       Default     0x0                  0      0    kernel: (kernel) VoodooI2CPCIController::pci8086,2e8 Starting I2C controller
2020-02-14 12:49:31.353167+0100 0xf5       Default     0x0                  0      0    kernel: (kernel) VoodooI2CPCIController::pci8086,2e9 Starting I2C controller
2020-02-14 12:49:31.356766+0100 0xf4       Default     0x0                  0      0    kernel: (kernel) VoodooI2CPCIController::pci8086,2e8 Set PCI power state D0
2020-02-14 12:49:31.357060+0100 0xf4       Default     0x0                  0      0    kernel: (kernel) VoodooI2CPCIController::pci8086,2e8 Publishing nub
2020-02-14 12:49:31.357418+0100 0xf9       Default     0x0                  0      0    kernel: (kernel) VoodooI2CControllerDriver::pci8086,2e8 Probing controller
2020-02-14 12:49:31.357565+0100 0xf5       Default     0x0                  0      0    kernel: (kernel) VoodooI2CPCIController::pci8086,2e9 Set PCI power state D0
2020-02-14 12:49:31.357810+0100 0xf5       Default     0x0                  0      0    kernel: (kernel) VoodooI2CPCIController::pci8086,2e9 Publishing nub
2020-02-14 12:49:31.357948+0100 0xf9       Default     0x0                  0      0    kernel: (kernel) VoodooI2CControllerDriver::pci8086,2e8 Unknown Synopsys component type: 0xffffffff
2020-02-14 12:49:31.414039+0100 0xfe       Default     0x0                  0      0    kernel: (kernel) VoodooI2CControllerDriver::pci8086,2e9 Probing controller
2020-02-14 12:49:31.419961+0100 0xfe       Default     0x0                  0      0    kernel: (kernel) VoodooI2CControllerDriver::pci8086,2e9 Unknown Synopsys component type: 0xffffffff
