1 hour ago, ahmedgamal09 said:
can you help me please here
u use many acpi renames, is impossible one good config with that
3 hours ago, innerd said:
Hi, can you help me with my touchpad?
skylake check a repo dsdt patch voodooi2c
4 minutes ago, innerd said:
Thk for the help, using open core with the same config.plist touchpad doesn't work with this DSDT.
check voodooi2c dsdt repository patch
in ur case u need it i think
Hi sir, I installed the olarila 10.15.6 for PC on my laptop which is an Acer A315-53, 8gb ram, i5 8250U and Intel UHD620. I copied over the OC folder from this website and thankfully it boots but with some issues. Before copying over the OC folders I had ethernet working with en0 on the USB key but now it doesn't work. Secondly the trackpad which is an elan i2c doesn't work either. I really enjoy your works better since you go that extra mile to ensure the happiness of users. Kindly help me get this system working smoothly. Thank you.
remove these renames in acpi tab
and add that
<dict>
				<key>Comment</key>
				<string>EC0 to EC</string>
				<key>Count</key>
				<integer>0</integer>
				<key>Enabled</key>
				<true/>
				<key>Find</key>
				<data>RUMwXw==</data>
				<key>Limit</key>
				<key>Mask</key>
				<data></data>
				<key>OemTableId</key>
				<data></data>
				<key>Replace</key>
				<data>RUNfXw==</data>
				<key>ReplaceMask</key>
				<data></data>
				<key>Skip</key>
				<key>TableLength</key>
				<key>TableSignature</key>
				<data></data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>Olarila Fix Boot Stuck</string>
				<key>Count</key>
				<key>Enabled</key>
				<true/>
				<key>Find</key>
				<data>oAqTU1RBUwE=</data>
				<key>Limit</key>
				<key>Mask</key>
				<data></data>
				<data></data>
				<key>Replace</key>
				<data>oAqRCv8L//8=</data>
				<data></data>
				<key>Skip</key>
				<data>RFNEVA==</data>
			</dict>
reboot and extract new sendme
check if bios/uefi have a option trackpad advanced
and add that
<dict>
				<key>Comment</key>
				<key>Count</key>
				<key>Enabled</key>
				<true/>
				<key>Find</key>
				<key>Limit</key>
				<key>Mask</key>
				<data></data>
				<data></data>
				<key>Replace</key>
				<data></data>
				<key>Skip</key>
				<data></data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Count</key>
				<key>Enabled</key>
				<true/>
				<key>Find</key>
				<key>Limit</key>
				<key>Mask</key>
				<data></data>
				<data></data>
				<key>Replace</key>
				<data></data>
				<key>Skip</key>
			</dict>
After deleting those "rename" entries and adding what you said(I did't really get that part well so I used BBedit to add that to config.plist), OC won't boot anymore. I am very noob with this please.
we need a clean start ;)
Done a clean start but with both 10.15.6 USB booted to desktop Ethernet is recognized as en0, copying over my old EFI which has everything else working with the exception of trackpad the Ethernet completely disappears. If there a way you could check the EFI for errors for me? If for a fee I'd scrounge up something.
post efi here
2 hours ago, Vincenzo Pappaterra said:
I can't get the trackpad to work on my Lenovo Ideapad-S340-15IWL laptop with OpenCore in any way. HERE is my SendMe file
  • Thanks 1
