18 hours ago, MaLd0n said:
first use a macbookpro13,1 smbios
smbios changed to macbookpro13,1
Now trackpad works ? but unstable and No multitouch
plus, IOReg still doesn't show ACPI ID
Edited by Rezarg
Laptop : Acer Aspire E5-575g-73wp, i7-6500U, GTX 940mx/HD 520
USE VoodooI2C.kext and VoodooI2CHID.kext
Hello MaLd0n
problem solved
trackpad is full functional and now IOReg shows my ACPI ID ?
thank you so much for your support and patching my DSDT
4 minutes ago, Rezarg said:
problem solved
enjoy
On 1/22/2020 at 4:54 PM, strangeralot said:
Hello everyone.
I put Mojave 10.14.6 in a Dell Inspiron 15 3000, i15-3583-D3X. Everything is ok, except the multi gesture of trackpad. I dont have scroll and two fingers touch (right button) in touchpad. Someone know what I should have do to enable at least the scroll?
Mald0n help me in another topic and instructed me to update my kexts, I used kext updater and just the VirtualSMC and WhateverGreen I can't update because the last versions of this kexts bugs the boot.
Mald0n even told me to exclude ps2mouse and ps2trackpad kexts, because my touchpad are I2C ( my APCI ID is TPD0). I did, without sucess.
I did this guide of this topic, whitout success too.
Here my Send me.
Please, someone can help me?
Thank you.
Hello, I have a laptop like that too, could you please send the links to download the OS and the software used? If it is possible to explain, I thank you very much!
I already did a hackintosh on my old Lenovo, but several things didn't work and I couldn't get all the kexts.
Thank you!
Hello,
I Have a Samsung X20 (NP350XAA-KFWBR) with ATMEL3000.
I could´t find the strings:
1. ACPI ID
2. APIC Pin Number
3. Ensure I2C Serial bus name are correctly labelled in DSDT.
Even looking in Windows. It seems to have different name entries.
Could anyone give me a hand?
Thanks.
I´m runing Mojave 10.14.6
Aida report: https://drive.google.com/open?id=1z5VVoD9iuDCv5EiLarMrWxgdkoi7223L
Send-me.zip:  https://drive.google.com/open?id=1oeDZ3urcJLIkI17ZSMRPDiG7Sf_BGG8X
3 hours ago, Avenger-RP said:
Hello,
this trackpad in some cases don't work, never, avoid samsung with i2c
try this folder
https://filebin.net/jlbcaalocrc36ku8/EFI.zip?t=ucwj1rc1
Hello guys
I installed the mojave hackintosh on my ideapad 330, I'm using the latest versions of VoodooI2C.kext and VoodooI2CHID.kext to my trackpad and VoodooPS2Controller.kext to my keyboard, and the pinning with https://www.olarila.com/ topic / 5644-enable-i2c-trackpad-voodooi2c-not-a-guide-not-really /
but my trackpad ends up working like a usb mouse, and the worst part, it keeps "jumping" when I use it.
I'm doing tests here and I noticed that, no matter what PIN I put on GpioInt SBFG, it doesn't change it behavior.
And I also noticed that the "jumps" only happen when the notebook is using the battery, it doesn't happen when it's plugged in.
could someone help me?
Clover and send me
https://drive.google.com/open?id=18oElJPUOLud2Lg5DW8EZS3tiOvggwDK9
On 5/19/2020 at 11:05 PM, luccasoli said:
Hello guys
is not ellan, is a different device
10 hours ago, Ilaiga Archer said:
I Have HP Probook 440 G7/ Can anybody help me make touchpad  i 2 C
Had someone managed to make it work Samsung X20 (NP350XAA-KFWBR) ?
I made all the procedures but no way.
Even the pinout is the same as in the example.
Já responderam antes, desculpe.
Edited by Avenger-RP
13 hours ago, Moshe Lyahovsky said:
hi I get frequent kp with voodooi2c it detects the hub and right after it kp if you want I can send you all of my dsdt and stuff but I read that the is a usual thing yoga 2 pro its elan
12 hours ago, ahmedgamal09 said:
ic mad patches for my touch pad in OpenCore and it's working but in poling mode and it's lagging when I used the same patch with clover it's working in interrupt mode but not with OpenCore can you help me to fix it
