Hello. I need help.
3 and 4 finger gestures do not work. But in system monitoring cpu loading change when fingers count on touchpad changed. 2 finger gestures work well.
I use VoodooI2CHID. I tried to use ssdt patches received using geni2c, but in GPI0 mode and APIC mode my touchpad work same.
Laptop: MSI GL65 9SC-002
CPU: Intel Core i5-9300H
OS: macOS Catalina 10.15.3
VoodooI2C + VoodooI2CHID: 2.3 version
I2C HID Device, ACPI CUST0001 PNP0C50, (custom touchpad)
bios: SB.PCI0.I2C2.TPD0
ven:8086 dev:A36A
I2C0 reserved for touch screen, which I don't have A368
I2C2 is for touchpad A36A
Here you can see my EFI: https://github.com/RafiZz/msi-gl65-9sc-hackintosh/tree/dev/
voodooi2c_report.zip
9 minutes ago, Rafis Bikbov said:
Hello. I need help
u need report it to voodooi2c project
Clarification: gestures of 3 and 4 fingers work as if 2 fingers
36 minutes ago, riyanardian said:
what is that mean ? there is my screenshoot
check what solution app provide for ur case
9 minutes ago, riyanardian said:
is my kext correct? the trackpad working like mouse only, there is no option for gesture
is trackpad is loading but not full, try a gpi0 patch and return into _crs
https://imgur.com/hj1LAo9
Try to remove "VoodooPS2Mouse.kext" and "VoodooPS2Trackpad.kext" from "VoodooPS2Controller.kext/Contents/PlugIns"
still not working ?
Can someone help me pls? my problem is that my trackpad doesn't work To make it work, I need to deleted my kext from the Kexts / Other folder, and put them back there, rebuild the kextcache with sudo kextcache -system-prelinked-kernel reboot and it worked, then I rebooted and it no longer worked . its like random if it will work or not.
WORKING:
http://s000.tinyupload.com/index.php?file_id=20261312987899219841
NOT WORKING:
http://s000.tinyupload.com/index.php?file_id=40792482548307332919
I could not find any difference when it works and when not more than in the IOReg, below my TPDX device more things appear when it works, but in the bootlog and the kernel log I did not find anything different. Please someone help me :(
update kexts and bootloader
Hello
I'm followed this guide step by step but no working for me
I edit My DSDT and apply GPI0 controller patch but IOReg doesn't show ACPI ID
My windows ACPI ID:: TPDE
My ELAN based on ACPI: ELAN0501, ELAN0511
please help me
Edited by Rezarg
Laptop : Acer Aspire E5-575g-73wp, i7-6500U, GTX 940mx/HD 520
7 hours ago, Rezarg said:
Hello
first u need a folder with correct settings, check here
https://www.olarila.com/topic/5676-clover-folder-for-all-chipsets/
for start with a good config
now I using olarila config but Nothing has changed and My trackpad Does not work and Thermal subsystem no longer installed
only I'm removed some DSDT Rename like GFX To IGPU based on FAQ whatevergreen and AppleALC
Edited by Rezarg
10 hours ago, Rezarg said:
now
first use a macbookpro13,1 smbios
