Hi, I am having difficulty patching the ELAN 1200 Touchpad
My IOinterruptSpecifers DATA is <39 00 00 00 03 00 00 00>
and my GPIO pin is based on CannonPoint-H
here are the values i got from cannonpoint-h
GPP_B9 = 34
GPP_J9 = 296
GPP_f9 = 225
CNL_GPP(1, 25, 50, 32), / GPP_B /
34 25 50 32. = 41 pin=(29)
CNL_GPP(2, 269, 286, 320), / GPP_I /
296 269 286 320 = 347 pin=(15b)
CNL_GPP(3, 216, 239, 288), / GPP_F /
225 216 239 288 = 297 pin=(129)
i even tried the 0x17, 0x1B, 0x34 and 0x55 pins but nothing is working!
i am sorry for the kexts i have installed in /S/L/E! please find the attached file.
Send-me-Ankits-MacBook-Pro.zip
Hi
first use a good config, Olarila folder for ur chipset
Arquivo Comprimido.zip
thanks, now I am using your config and ran the test again. please check.
no, stay wrong
no, stay wrong
hey, sorry for being this noob, I wasn't aware of this forum.
Touchpad is working finally! thank you so much used your Olarila clover folder for coffeecake now its working.
Hello everyone.
I put Mojave 10.14.6 in a Dell Inspiron 15 3000, i15-3583-D3X. Everything is ok, except the multi gesture of trackpad. I dont have scroll and two fingers touch (right button) in touchpad. Someone know what I should have do to enable at least the scroll?
Mald0n help me in another topic and instructed me to update my kexts, I used kext updater and just the VirtualSMC and WhateverGreen I can't update because the last versions of this kexts bugs the boot.
Mald0n even told me to exclude ps2mouse and ps2trackpad kexts, because my touchpad are I2C ( my APCI ID is TPD0). I did, without sucess.
I did this guide of this topic, whitout success too.
Here my Send me.
Please, someone can help me?
Thank you.
I tried, unfortunately no luck.
u have a last i2c kexts version
I had the 2.3 on mojave and same on Catalina.
--Run_Me
RunMe.app
Sure
very wrong config, many wrong renames like _dsm to xdsm, etc
check Olarila folder for clean and correct renames, config etc
thank you now its working! :crazy:
On 1/19/2020 at 10:19 PM, SG88 said:
Hey guys, I am following the first page to try to activate the trackpad on my Lenovo s340 ideapad.
GPI0 is CannonlakeLP
ACPI ID:TPAD
APIC Pin num: 0x50 --> dec 80
0x50 in the IRQ table of CANNONLAKELP is:
GPP_C8_IRQ --> in decimal 189
GPP_H8_IRQ -->in decimal 125
Now if I go here (https://github.com/coolstar/VoodooGPIO/blob/master/VoodooGPIO/CannonLake-LP/VoodooGPIOCannonLakeLP.hpp) I can't find those decimals. I am stuck in this point. Anyone has some suggestions?
Hi,
did you get it to work?
I have the same problem.
Nothing worked for me.
Cheers
10 hours ago, Tomas Šaduikis said:
Hi,
first try with windows patch and i2c kexts
